Help with TSI t25 Dual BB turbo wont fit
Old Oct 28, 2011
I <3 My EM2's Avatar
I <3 My EM2 is an unknown quantity at this point
I have a TSI kit I bought used, well the turbo and manifold.. I bought new piping and such, but i went to drop the turbo and manifold in and it seems to big to fit in the little space. I been trying to jimmy it in but stuff is in the way.
this is about as far as i got it in :/
Old Oct 28, 2011
MindBomber's Avatar
Live for the Twisties
Re: Help with TSI t25 Dual BB turbo wont fit
Yup, that sounds like a tsi kit.
What's in the way, the radiator fans?
Old Oct 29, 2011
Yeah the radiator fans, A/C line and clutch cylinder I managed to jam it in but got stuck on an ac line bracket and such
Old Oct 29, 2011
MindBomber's Avatar
Read this thread, it looks like there was a lot of discussion on how to get those things to fit and what had to be changed or modified to make it happen.
https://www.civicforums.com/forums/7...bo-kits-2.html
Old Oct 29, 2011
Ok thanks , well now the air exit part of the turbo is hitting the slave cylinder , this is a nightmare
Old Oct 29, 2011
MindBomber's Avatar
I read the entire TSI thread, it's amazing the lengths I'm willing to go to help someone while avoiding homework lol.
I see tons of discussion of manifold fitment issues between the manifold and fans, including grinding up to 1/4 inch off the manifold (that's nuts), but no mention of clearance issues with the slave cylinder. How bad is it hitting?
Old Oct 29, 2011
Haha thanks a lot man, and yeah i read that part about grinding some off, i havent seen anything where i've needed to grind except for part of the radiator frame.. i took off the inlet flange and got it in even more so it wouldnt hit the slave cylinder now it needs to be moved right about 3/8 inch but now the A/C line is in the way lol
Old Oct 29, 2011
MindBomber's Avatar
AC line shouldn't be to difficult to work around, they move, slave cylinders.. don't.
Is it one of the AC line brackets or the line itself, by how much does it need to move?
Old Oct 29, 2011
Ok I bent the ac metal line and got the manifold mounted to the engine.. next problem is the clearance between the slave cyl and the intake flange.. theres very little space to get the coupler on.. ill be taking pics to upload and maybe do a build thread
Old Oct 29, 2011
MindBomber's Avatar
Sounds like you've been working through the problems pretty well, good work.
Definitely do a build thread.
Old Oct 29, 2011
Old Oct 29, 2011
See the images i posted... look at the clearance of the intake inlet and the slave cylinder mount and nuts.. idk how im gonna get the intake hose on that
Old Oct 29, 2011
MindBomber's Avatar
pics aren't working for me.
Old Oct 29, 2011
wierd... shows up for me.. its hosted on dropbox
Old Oct 29, 2011
MindBomber's Avatar
maybe it's just my computer
Old Oct 29, 2011
Shift-E's Avatar
That Dude with the Questions
Not showing up for me either. Try uploading them on this site?
Old Oct 29, 2011
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Yea, I cant see any of the pics too
Old Oct 30, 2011
i managed to get around all my problems. . turbo manifold in on , along with the turbo and the intake is on...
Oil pan is dropped and tapped
Front bumper is removed
emanage is installed
Now i gotta figure out how to get the damn oil pressure sender/sensor out to T it.. its in really in the block and tight and the space to work in is tight
I also gotta go get my downpipe remade because it doesnt fit -_-
well i guess im gonna drop the injectors in now
Old Oct 30, 2011
Aetoc's Avatar
For the oil, it may be easier to get a sandwich plate adapter or filter relocation kit for the oil line out/pressure sender hookup. The sandwich plate has multiple fittings for oil lines.
