Saab Turbo In A Civic?
Old May 31, 2011
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Question Saab Turbo In A Civic?
Would a T25 turbo from a Saab work on a 2001 Honda Civic? Info on the turbo here:
http://forum.ecuproject.com/showthre...ications/page6
I would be putting out 10 lbs of boost (1.68 pressure ratio), and full boost at 10.19 lbs of air/min @ 4,000 rpm through 17.2 lbs of air/min @ 6,750 rpm (redline).
Has anyone tried this before?
Old May 31, 2011
sl33pyriceboi's Avatar
Re: Saab Turbo In A Civic?
to answer the question, yes you can put a t25 in there. heck you can put any turbo in there with the correct manifold
and if you dont plan on having an internal build and a strong intake manifold, ur going to blow ur engine real quick.
Old May 31, 2011
MindBomber's Avatar
Live for the Twisties
The stock intake manifold is just fine, it flows poorly, but it won't blow up.
With the correct turbo manifold any turbo will work fine, your concern needs to be on getting k-pro and having your engine built to accept the amount of boost you plan on running.
Old May 31, 2011
due to the way our intake mani is designed, the plastic part that acts like a cup is the first thing that goes bad. ive seem at least a few members who have been boosted complain about that.
if you are serious about pushing that much air, id suggest you take a look into the D16y8 conversion.
Old May 31, 2011
MindBomber's Avatar
I see so much conflicting information on our stock im with a turbo..
I know it flows very poorly due to the way it makes the air curve, but many people also say it can't handle boost and will crack since it's plastic, but Paul said it will handle 25psi all day..
Old May 31, 2011
i guess it depends on external factors like the weather, temp, if there are small cracks, or even a build up of water in what seems like a bowl....etc
Old May 31, 2011
MindBomber's Avatar
Hmmm... I can see external factors being a factor, but not enough to actually cause cracks.
Old Feb 14, 2012
mac25's Avatar
Dr Krieger of Modification
this is the closest thread i could find and i didn't want to start another turbo thread, lol. so here goes.
i might want to buy stock parts from used cars and wanted to know some good cars to look for or are there any?
i'm guessing since the D is a 1.7 i should look for cars with engines from 1.6-2.0l that are boosted stock?
such as a gti
i'd be looking for
-the charger
-waste gate
-Bov
-intercooler
-maybe injectors
-maybe oil return lines
then buy new engine managment, piping, the exhaust manifold and get it tuned.
Old Feb 14, 2012
SlimRisk's Avatar
Busy Speeding!!
That's what I was gonna do for my turbo build. Check saabs, dodge neons, volkswagens and audis. Saabs turboed a lot of their cars, I see turbos on them all the time at the junk yard (some came with front mount longitudinal intercoolers too), one edition of the dodge neon, the srt4, came turboed. And then Volkswagen and Audi, since they're owned by the same company, turboed a lot of their cars. The only downside is factory turbo cars sometimes cools the turbo with coolant to help the turbo live longer. Idk how to set that up. Check chozobody he's got a factory turbo, down pipe, and then the right exhaust manifold for out cars
Old Feb 14, 2012
mac25's Avatar
thanks for the list man! keep em comint so i can research the factory numbers =D
Old Feb 14, 2012
This. I'd want something from nearly the same size engine, or maybe slightly smaller to reduce lag time. Like a turbo from a 1.6.
Also consider the RPM redline of each engine and figure that into your volume calculations before selecting one. (A 1.6 that can turn 7000 vs. a 1.7 that can only turn 6500, etc.)
You wouldn't want to pick a turbo that is too big, like from a Cummins Diesel. You just don't have enough displacement to make that work.
I have a turbo that came from a 12A Rotor Motor that would turn 9000rpm@14psi, and I wouldn't even think of putting it on anything smaller than a 210cid engine. It would easily feed a 5.0 that has a 6000 redline.
Old Feb 14, 2012
Miscreant13's Avatar
Miscreant13 is an unknown quantity at this point
Wow... all this trubo talk kinda makes me miss my srt4... and definitely makes me miss my Saab!
Old Feb 14, 2012
SlimRisk's Avatar
Busy Speeding!!
Hey guys, I already covered turbo mathematics in a thread of mine
Old Feb 15, 2012
mac25's Avatar
can you find the link for me Slim? thx, even if not =D
Old Feb 15, 2012
SlimRisk's Avatar
Busy Speeding!!
https://www.civicforums.com/forums/7...lations-d.html
cloudguy
Apr 28, 2015 05:02 AM
Boosted
Nov 21, 2003 11:03 PM
supraman
Nov 6, 2001 05:50 PM
LexBoy
Nov 5, 2001 08:00 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
