in your opinion (d17a2)
Old Sep 3, 2010
team_takeout's Avatar
team_takeout is an unknown quantity at this point
what is the best mods to do
i want a cai
and an exhaust
i have a vtec engine and wanna know what i could do to it to get the hp up a bit ( from what i understand after reading up some it is at 127 hp stock) i would like to get it to about 175
any recommendations?
thanks
Old Sep 3, 2010
Re: in your opinion (d17a2)
hahaha!
swap in a k series or turbo (but do a good setup).
You need to read more.
look for at least 5k or more for a good setup.
your short cut could get a short engine life.
Old Sep 3, 2010
i was thinking about a turbo anyways
which would you recommend
ive heard good things about greddy
what do you think?
Old Sep 3, 2010
I think you need a thourgly read in the other forum, forced induction.
https://www.civicforums.com/forums/1...rced-induction
Doing it right at the first time or your going to loose the engine.
Read around here and you should find what you need but it is not going to be as easy as bolt-on's.
you might also look around the 7th gen forced induction and swaps - the swap for a k-series, be it K20, 22, 24, might be a better option finbancial-wise.
https://www.civicforums.com/forums/7...nduction-swaps
Look also for hasport web page.
There is no short-cuts, it will take money. I am still waiting for my D17A2 to go out so i can consider a swap. I have a spare miata to live with when time comes. But will thorow me to SM class in AX...https://www.civicforums.com/forums/7...duction-swapsr get a 6th gen.
Old Sep 4, 2010
02civicsi02's Avatar
Low and slow!
You will not make 175 whp off the d17a2 unless you boost. The d17a2 only has like 90 something to the wheels and dont really respond will to anything from what I have seen and read. So if you want to keep your stock motor then turbo. If you want an easy as hell root and still be perfectly realible then k20 or k24 swap. You can swap in the k20a2 and already be at your goal. The k20a2 has 200 hp to the crank and 178 to the wheels. You would reach your goal and you can be stock.
Old Sep 4, 2010
i dont wanna sound like a noob or anything but do you know a reliable place where i can get one of those (k20a2) and if i do the swap will i have to replace anything else besides the engine
or will i just remove the old and put in the new
Old Sep 4, 2010
Low and slow!
You can go round salvage yards looking for rsx type s that have only been hit in the rear and get the motor for cheaper than probably another seller. And you will need a couple things not just the motor. I think there is a thread on here some where for swapping in the k series in base 7th gen. You will need motor mounts, motor/tranni, rsx shifter assembly and linkage, axles, ecu, and not sure what else.
Old Sep 5, 2010
did you see the links i posted? ...
Luluharp
Sep 27, 2015 11:56 AM
General DIY
Sep 25, 2015 08:02 PM
curaze
Sep 22, 2015 08:27 AM
bashea
Sep 15, 2015 04:59 AM
rayaan_wasty
Sep 14, 2015 02:00 PM
