sub frame
Old Jan 15, 2010
boosted2cam's Avatar
boosted2cam is an unknown quantity at this point
sub frame
i did a auto to manual swap..do i really need a new sub frame? Do i need that front motor mount?
Old Jan 16, 2010
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Re: sub frame
yes you need the subframe and the front motor mount
Old Jan 16, 2010
Re: sub frame
do ibuy a manual front motor mount too?
how come i read some ppl doing it without the manual subframe
Old Jan 16, 2010
Re: sub frame
that engine mount is pretty important! im not sure which one you would use tho, i would guess if you use the manual subframe, then you need the manual motor mount, since it bolts up differently to the frame. i doubt the auto mount would work with manual subframe.
Old Jan 16, 2010
Re: sub frame
I wonder what this guy is talking about..
these are the parts anyone you says different does not know ****
1.)everything listed above -ECU (PM me to find out how to make your ECU work)
2.)master/slave cyl.
3.)clutch/ flywheel
4.)shifer cables (buy new)
5.)axles(yep they are different)
6.)tranny side mount, and front engine mount
7.)new subframe, our have someone move the front mount bracket 1 1/8 inch to the right if you are facing the car
8.) manual tranny starter
9.) misc. nuts and bolts
10.) new guage cluster or paint old one
11.) A LOT OF BEER
*** I would also recomend a helms manual (not just recomend it is the most important thing you could buy) and alot of borrowed tools from autozone
If you have any questions PM me
Old Jan 16, 2010
Re: sub frame
i think he means cut and reweld the mounting bracket (for motor mount) on the old frame, or swap in the new frame.
Bruce2
Sep 21, 2015 08:01 PM
nixyfior
Sep 14, 2015 08:32 PM
michael0219
Sep 1, 2015 10:25 PM
jonwalden68
Aug 27, 2015 12:07 PM
SuperGroove
Aug 18, 2015 07:55 AM
