Need Some Opinions
Old Apr 8, 2009
TeraCivic's Avatar
TeraCivic is an unknown quantity at this point
Need Some Opinions
Ok, Here's the setup I pieced together off the net. I was looking for some input on it. Also if I left something out let me know.
Turbo Charger TB0335 Garrett 195
Turbo Downpipe/Manifold 250
F/I Controller VAFC II Apexi 280
Fuel Injectors Denso 125
Intake Piping/Intercooler 180
Turbo Oil Lines 85
Blow-Off Valve Super SQV HKS 130
Fuel Pump 255LPH Walbro 100
Turbo Timer? Type O HKS 100
Total 1445
Old Apr 8, 2009
Re: Need Some Opinions
um youre gonna need a much better fuel controler than a vafc for tuning.
Old Apr 8, 2009
TeraCivic's Avatar
What would you suggest i wasnt to sure about that one.
Old Apr 8, 2009
TeraCivic's Avatar
Just got done doing a lil research and it seems that Greddy's E-Manage could be the best for the money. What do yall think about it? Has anyone here used it?
Old Apr 8, 2009
um gonna have to do alot better lol. i wouldnt even bother unless you have AEM EMS or hondata if they make a programmable ecu for your car. just throwing on a turbo kit is gonna cause huge problems for you all the time. i think for a 99si, you would be better off getting a supercharger kit made for the car, and the vortech aftercooler if you need even more power. plenty of guys make around 225whp with that setup.
Old Apr 8, 2009
TeraCivic's Avatar
I would like to stay away from superchargers as they use power to make power costing me more fuel to make the same power a turbo would. I only plan on running around 7 psi with stock internals. You said just bolting on a turbo kit will cause me problems, what kinds of problems are you refering to? As for the ecu I am trying to stay under 2 grand so the aem ems is out along with any stand alone. I live in a small country town and I don't think we really have any tuners around here , but I haven't looked very hard, so I will probably end up doing a lot of the tuning my self.
Old Apr 8, 2009
your main problems will come if the engine is not tuned properly under boost. using any type of piggyback fuel controler is asking for trouble. even properly tuned, they suck. if youre gonna do that i suggest holding off until you can afford a real tunable ecu. and you need a good tuning shop with a dyno.
Old Apr 9, 2009
TeraCivic's Avatar
Ok I guess I'll have to save then lol. Besides the ecu is there anything else i'm missing or could do better picking out.
Old Apr 9, 2009
TRIZ's Avatar
Wastegate?
Old Apr 9, 2009
TeraCivic's Avatar
The turbo i found has an internal wastegate, or would it be worth it to get an external?
Old Apr 10, 2009
TeraCivic's Avatar
Ok, I've been doing some research on the ecu issue. Could i get a p28 ecu and an obd conversion harness and put a hondata s300 in it? Is the p28 w/ obd conversion just as simple as changing the ecu, doesn't seem like it would be?
Luluharp
Sep 27, 2015 11:56 AM
General DIY
Sep 25, 2015 08:02 PM
curaze
Sep 22, 2015 08:27 AM
bashea
Sep 15, 2015 04:59 AM
rayaan_wasty
Sep 14, 2015 02:00 PM
