K20 Swap Serpentine Belt Change
Old Mar 5, 2009
feet_'s Avatar
feet_ is an unknown quantity at this point
Just wondering if anyone had experience with a K20A2 Serpentine Belt Change, in the 01-03 civics.
Just noticed a tiny spider web crack on my belt, right in the middle of the belt.
It looks real tight in there.
Old Mar 5, 2009
sl33pyriceboi's Avatar
Re: K20 Swap Serpentine Belt Change
if you see cracks in ur belt, it means its time to get a timing belt change... simple as that =]
Old Mar 5, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ i think he knew that already. lol..
yeah its a real bitch to change the belt in almost any honda because the space is so limited, not to mention your k20 is in a civic.. if its not too difficult for you some people like to lift the motor out of the engine bay a little and then change the belt to make things a lot easier.
Old Mar 5, 2009
D5cIvIc's Avatar
what do you need to know about changing it? i changed it twice.
Just get a tensioner wrench and take out ur old one and put in your new one.
Space is limited, but you can get it in there no problem.
Please do not lift out the motor just to install a serpentine belt.
do you have an a2, a3? do you run PS or you running the idler pulley?
Old Mar 5, 2009
D5cIvIc's Avatar
double post
Old Mar 14, 2009
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
hey its not hard at all. if you remove your engine your an idiot lol. answer d5civics questions and you'll know your next move. basically you turn the autotensioner with a ratchet and socket and remove the old belt. reverse order for installation. Space is tight though. remember its orientation when removing.
Old Mar 19, 2009
streetthrowback's Avatar
streetthrowback should not be trusted
yup, takes like 10 sec to replace, lol but yet i dont have a/c or p/s
mattdoc
Mar 14, 2017 12:10 PM
marciano117
Jun 25, 2015 09:06 PM
beachglass
May 22, 2015 09:59 PM
slynger
18
May 8, 2015 06:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
