vtec swap o2 sensor codes HELP!!!
Old Dec 14, 2008
dcivic01's Avatar
dcivic01 is an unknown quantity at this point
i have a 01 lx with ex head, vafc2, racing header w/ header wrap, mild port and polish, decked the head some, and now my car is throwing o2 sensor codes. wondering if anyone knows where to get o2 dummy or simulators. if not then how i can trick the ecu to thinking its running right?
Old Dec 14, 2008
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: vtec swap o2 sensor codes HELP!!!
almost anywhere....
try www.dezod.com
www.procivic.com
there is a DIY for making a defouler here too I think. I personally would have just gotten a shorty header with a high flow cat downpipe so I could still pass inspection....but thats just me.
Well speaking of, you could take it to a muffler shop, buy a proper sized high flow cat and have them weld in the bungs and extend the wires....problem solved and you can still drive it legally with the race header. Good luck
Old Dec 14, 2008
dcivic01's Avatar
thanks i just recently started looking for the dummy o2s but it had the bungs already and i tried the defouler and still threw codes so i am just going to eliminate them all together.
Old Dec 28, 2008
gmcuajo's Avatar
gmcuajo can only hope to improve
i use a MIL eliminator from eBay (obvious on the 2nd O2 sensor). some 4 years and no problems.
Old Dec 28, 2008
gmcuajo's Avatar
Never mention if you remove the cat. If you still have a the cat converter, then you should look for problem and fixing...
Old Dec 28, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ race header usually implies a cat delete.
you can just extend the O2 sensor out about 3 inches out of the exhaust flow in the exhaust. thats what i did, worked like a charm.
runawaykinms
15
Mar 22, 2019 10:32 AM
juicetayne
Sep 30, 2015 11:02 AM
PunX
Sep 23, 2015 10:45 PM
Uan
Aug 23, 2015 03:03 AM
Dani1993
Jul 24, 2015 09:02 AM
