Removing K-series tranny
Old Sep 3, 2008
k20EX's Avatar
k20EX is an unknown quantity at this point
Has anyone removed the transmission from their k-swap without having to pull the entire engine? My transmission is making an odd rattle/vibration, but it is not when the clutch is pushed in. It appears to make this noise after I have shifted gears and the clutch pedal is released. I have a feeling I may have to remove the transmission now, and wanted to know if anyone has removed it without unbolting the engine/tranny? Any help would be greatly appreciated!!
Old Sep 3, 2008
valenzuela's Avatar
valenzuela should not be trustedvalenzuela should not be trustedvalenzuela should not be trusted
Re: Removing K-series tranny
if your doin this on jack stands in the garage better hope you can lift the car like 2 - 3 feet in the air. but yea you can do it. it's not as hard as it seems. just remove the sub frame trans mounts starter shifter linkage and unbolt the trans for the most part. what i do with the axles is just pop them out of the trans leave the other end still in the knuckle. i mean i usually work on a lift at work. but ill be glad to help just p.m. me
Old Sep 4, 2008
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
yes i have done it with a jack and a couple jackstands. the car need to be high. you remove everything except for the passenger side motor mount so it pivots down at an angle. I think it is easier than pulling the d17 tranny
Old Sep 4, 2008
k20EX's Avatar
Excellent.....thanks for the advice. I have been getting a loud buzz/vibration/rattle from my tranny and Im not sure whats going on yet. It's not quite a grind, and it goes into every gear fine. It just does it after I let off the clutch after I go into a gear. At least I know that it can be done without something ridiculous.
Old Sep 4, 2008
You VTEC...I-VTEC
i would recommend 4 jack stands(2 for the car) for this job and maybe an extra hand since the k series tranny is so heavy
May 4, 2016 07:14 AM
beeemerdude
Jul 23, 2015 03:53 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
