turbo rebuild problem civic 1.4 turbo
Old Apr 30, 2008
akernohan's Avatar
akernohan is an unknown quantity at this point
I know alot of you wont have time for new people like me so Right long story cut short i need help with my civic 1.4 this seems like the site to go to. I'm new so you are going to have to bear with me on this one I'm not a great writer.
The turbo kit was going just great (if anything little low on power 130bhp) until I noticed I was burning a hell of alot of oil. I thought of the worse and started on replacing piston rings now I know it's the turbo oil seal.
The rebuild went just fine until start up. I have the worse idle in the world and it constantly stalls with clutch in or neutral. It has got so bad I cant drive it. I have heard something on air in coolant system and iacv system??? The boost gauge suggests i am loosing vac but it is variable. I have checked vac lines and tried idle control valve.
Any help would be much appreciated
Old Apr 30, 2008
familycar's Avatar
Re: turbo rebuild problem civic 1.4 turbo
Timing belt on correctly?? start the motor with out boost first, break it in then boost it! It will make it more difficult to figure out the problem with the turbo in place. You could laso have a valve adjustment issue. Who put the motor together?
Old Apr 30, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
did you clock the piston rings correctly? maybe you have no compression.
Old Apr 30, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
We'll....you've been into every single part of the motor......so back check everything! I would definitely perform a compression & leak down test asap to get your foot in the door. Then from there back track by what you know. Engine takes air,fuel,spark, & timing to run.......check all of these if your compression is good.......go from there man.......time to put your diagnostic gloves on!
Old May 2, 2008
akernohan's Avatar
Well the timing belt isn't on absolute perfect its maybe a few degrees advanced at most. Would it be worth doing that again.
Dont think taking out intake pipe will change it was working fine for a long time on boost.
Rings are on as in manual. Dont think its a specific cylinder. I do have compression or did.
Old May 2, 2008
FoSho's Avatar
hmm...well that may be your problem right there. Your timing belt only goes on 1 way. TDC on the cam & TDC on the crank. Thats it. Even if it's off a tooth it can cause issues. or are you refer. to your distributor timing?
Old May 6, 2008
akernohan's Avatar
ok will have a go at trying timing belt again to get perfect. any tips to getting it on right. Didn't know it could cause idle problems like this. distributor is the way it was before. think i might check intake manifold gasket at the same time. i think it ran better without the iacv plugged in so i thought the coolant thing was to blame.
Old May 6, 2008
andyman97's Avatar
Turbo Guru
Wow man, your timing belt is off a few teeth? Lucky if you don't have any bent valves. Start over and do **** right this time....
Old May 9, 2008
akernohan's Avatar
meant few degree but yeah still no good. What? Y start again all I have to do is take the timing belt off and go by the book a bit better this time.
Old May 12, 2008
familycar's Avatar
hopefully you didnt damage any valves
Old May 14, 2008
94EG6's Avatar
94EG6 is an unknown quantity at this point
I am assuming this is a 1.4 vtec motor if so,I hope nothing was bent bro.
The timing belt is a huge problem.One tooth off can cause weak power and maybe bent valves if the rpm gets high and the vtec engages.
Old May 15, 2008
akernohan's Avatar
havent been reving it that much since engine rebuild. I have heard no noises yet so i am hopeful that valves are ok. Dont really have time to cheak them so will just fix timing this weekend hopefully. It isnt vtec but i might do a conversion some day. Thanks for the help btw!
Old May 17, 2008
akernohan's Avatar
timing fixed (although wasnt far off)
yet to start up waiting on battery charging
other things that could cause problem:
evap reservoir solenoid on top broke off in rebuild
air in coolant system (some sensor which affects idle)
injectors???
Old May 20, 2008
akernohan's Avatar
so incase anyone wants to provide any input.
its not:
the evap purge thing (tried a new one)
problem with injectors of any sort (new seals, throughly cleaned)
the timing (redone)
wrong wiring to spark plugs (check)
have ordered new spark plugs just cause i cant thnink of anything else to do. Anyone think new wire will be needed. I think unlikly as it was working fine before.
just to remind ppl: there is hardly any vac on idle but kicks in after coming off the throttle. the idle almost always stalls. Iam not so sure about drive as i havent driven in such a long time.
i am really stumped here guys any suggestions welcomed.
Old May 21, 2008
drunkenmagnum's Avatar
What kind of Engine Management are you using? Is it hooked up properly, could your old tune be causing a problem? might want to check over it possible. Just a suggestion.
Old May 21, 2008
akernohan's Avatar
yeah thanks the management hasnt changed at all. just took it to good local mechanic he said the following:
check the valve clearances and do it to the values in manual.
he said the timing belt sounded too tight also which may be taking drive from engine.
Old Oct 28, 2008
akernohan's Avatar
does anyone know a clear process in which to tune a apexi neo. Or even check if it is working properly. I have a g-tech pro also & af ratio gauge. I have no clue how to fine tune it or even roughly as in not always rich as it is then leaning of to optimal around redline.
Old Oct 29, 2008
huntinghonda27's Avatar
huntinghonda27 is an unknown quantity at this point
You keep stalling out at idle and have a low vaccuum until you blip the throttle a little and let off, this sounds like something isnt seated right here. Check your intake manifold for any cracks or other sort of damage, make sure your throttle body is closing properly when you let off the gas, and check your valves. It is possible to have damaged them and a compression check will tell you if you are in trouble there. Buy a Hondata, they have good base maps that are safe to drive mildly on to get it to a dyno for a proper tune. Good luck and I hope you get it running soon.
Uncle X
Apr 15, 2015 09:59 PM
dooner24
Apr 14, 2015 07:51 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
supraman
Nov 6, 2001 05:50 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
