Injectors wont fit
Old Apr 15, 2008
drunkenmagnum's Avatar
Injectors wont fit
how do you make 450cc injectors, or any larger injectors, fit under the OEM fuel rail? i hear of people making them fit all the time but my mechanic days they wont fit because of the throttle body sensor. i am at work and unabl to see for myself at the moment.
any help would be great
Old Apr 15, 2008
03BlueCivic's Avatar
03BlueCivic will become famous soon enough03BlueCivic will become famous soon enough
Re: Injectors wont fit
if your using RC they wont fit. try SRT4 injectors. or the ones that dezod.com sells
Old Apr 15, 2008
dont tell me that ****! ughhhhhhh. i thought SRT-4's wouldnt fit either.
damnit
Old Apr 15, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
how short on room are you?
It depends on whats hitting the sensor, if its only the vent pipe on top of it, and it would otherwise fit, cut the vent pipe off, connect the hardline on the firewall to the canister on the fuel rail with a hose. That vent pipe is there for "packaging". Cut carefully though, you dont want to go through the rail itself.
You may just have to try another injector thats shorter.
Old Apr 15, 2008
yeah i am afraid i might have to.
has anyone to your knowledge made them fit?
Old Apr 15, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
all i know is that tons of people are running srt4 injectors.. try em!
Old Apr 15, 2008
i guess i will have to
what cc are the 05 SRT-4's. i know they went up a little that year.
Old Apr 15, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
It also had alot to do with what size bolts you have in the rail itself. My RSX's rubbed alittle till I played with several different bolt sizes
Old Apr 15, 2008
Jap-Euro Fusion
Just had an idea... Acura RDX's are 410cc. You need the clips from a Scion TC (i think?) and they're shorter than RSX ones. PM skipbarber... he did it.
Old Apr 15, 2008
ronaldo9's Avatar
Doesn't dezod sell modified stock injectors up to like 550cc deutchs or something like that.
Edit. http://www.dezod.com/pd_deatsch_werk...udes_clips.cfm
Old Apr 15, 2008
Rufus's Avatar
I have SRT injectors. They're the red and black ones. Just put washers on the rail. They didn't have fitment issues.
Old Apr 16, 2008
andyman97's Avatar
Turbo Guru
Yeah for 400 bux, no thanks...
Old Apr 16, 2008
i am looking for a OEM replacement like the SRT's which can be bought at a cheaper price. The RC's were 440, arent the 05-07 SRT-4's 5XX and the 04's 4XX?
can anyone help me with the sizes. what else might work? the RDX are a possible option but i want something at least 440 or bigger (the engine set up is good for 300hp)
Old Apr 16, 2008
Rufus's Avatar
This is what I have...
http://cgi.ebay.com/ebaymotors/SRT-4...spagenameZWDVW
My tuner said they weren't acting like 500+cc injectors. I think they come in at like 406cc or something
Old Apr 17, 2008
i have been bidding on those actually. trying to get um cheap.
Old Apr 17, 2008
andyman97's Avatar
Turbo Guru
It's so funny that you say that. An injector's flow rate is based on the amount of pressure it sees. Say RC engineering rates their injectors at 40 psi and they're 440cc, but Deatsch Works injectors are rated at 675cc at 35 psi. Guess which ones will flow more when they see 43 psi on a civic fuel rail....
So that may be the case, the srt injectors may be rated for higher fuel pressure and when you get them on a civic with lower pressure, you're seeing them max out quicker.
Key thing to keep in mind, flow rate is based on fuel pressure.
Old Apr 17, 2008
Rufus's Avatar
Actually I looked them up online and they really were a smaller CC than I had thought. However, I get your point.
Old Apr 17, 2008
where did you look up the info on CC?
Old Apr 17, 2008
Rufus's Avatar
I just googled it on my iphone while my car was on the dyno.
Old Jun 13, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
i have srt 4 injectors ... go to srtforums.com ... msg a member who's gone bigger turbo or make a thread ... get them for ~100 bux shipped... order the clips from dezod for change and u have 550cc injectors that fit amazing for under 200 bux .. jus make sure u have a good engine management to tune, FIC isn't good but it works well enough, thats the lowest u should go to tune those
GritzNGravy
Aug 19, 2015 03:03 AM
sf3r8z
Aug 11, 2015 02:32 PM
Green02civic
Jul 27, 2015 10:48 PM
EM_WON
Jul 22, 2015 06:49 PM
stvpagn
Jul 9, 2015 09:59 PM
