turbo oil inlet and drain help
Old Apr 12, 2008
dust's Avatar
dust is an unknown quantity at this point
Hey guys I am having a problem with my turbo. Im using a t25 with the hks mani. When mounted to the mani I can not clock the turbo so that the oil inlet and oil drain are going straight up and down. Anyone know a solution for this?
Old Apr 13, 2008
andyman97's Avatar
Turbo Guru
Re: turbo oil inlet and drain help
They don't have to be straight up and down. The feed line is pressurized and the return is gravity fed. As long as the return is between a 225 and 315 degree angle, you should be fine.
Old Apr 13, 2008
tfnaaf's Avatar
BLDNPSI Mod
I've got the same basic setup and mine are straight up and down
Old Apr 13, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
loosen the bolts holding the housings to the center and rotate it.
Old Apr 15, 2008
dust's Avatar
okay thanks guys
Old Apr 16, 2008
Rufus's Avatar
My drain has a 45 on it and it drops at an angle. For some brilliant reason we tapped the pan on the OTHER side of the exhaust. It works though. My feed wraps around the tranny and comes in from where the block is to meet the turbo rather than going around it (or over the head)
brags
46
Jan 7, 2016 09:39 PM
hoofboy
Jul 17, 2015 04:27 PM
Kyles24
Jul 12, 2015 09:15 PM
Jul 12, 2015 11:54 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
