Vacuum question
Old Mar 31, 2008
Rufus's Avatar
Vacuum question
I'm up and running with my turbo but need a little help with vacuum. When my kit was put on, the guys used a vacuum block on from the brake booster vacuum line. On the dyno, we immediately knew I was getting compressor surge. So the question was "is the BOV even working?" I knew it was getting some vacuum, so I switched it out and the same thing occured. Next, my ABS light came on. Clearly that line wasn't ideal for vacuum. Next I noticed that when I'm in boost, if I need to slam on the brakes, they're hard as hell for a few seconds. Obviously, I need a new vacuum source. Where do you guys pull your vacuum from?
Old Mar 31, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: Vacuum question
exact same place as mine. I get some compressor surge at lite throttle/low boost
Old Mar 31, 2008
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
Re: Vacuum question
Rufus, is that a Full Race logo I see?
Old Mar 31, 2008
Rufus's Avatar
Re: Vacuum question
It is. Everything is within a mile of each other down here in AZ
Old Mar 31, 2008
Rufus's Avatar
Re: Vacuum question
No ABS light on? On the block bottom I have the middle 3 plugged and the far left one going to BOV and the far right one to my wastegate. Maybe I have a leak....
EDIT: I see no ABS unit on your car. lol
I still have a very hard brake pedal during boost...
I'm at 175whp on 5.2PSI
Old Mar 31, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: Vacuum question
ABS light came on when it was strapped to the dyno?
Old Mar 31, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: Vacuum question
hard pedal under boost... i bet that you/they removed the check valve in the line. And they /you shouldnt have
Old Mar 31, 2008
Rufus's Avatar
Re: Vacuum question
No after driving it for a bit, just after the dyno. It went straight from the shop to the dyno (wasn't on the road at all)
Old Mar 31, 2008
Rufus's Avatar
Re: Vacuum question
I didn't. Hell, I thought that was all internal anyway. I'll ask to see if I can get it replaced.
Old Mar 31, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: Vacuum question
Just a guess would be they somehow damaged awheel speed sensor or they put it into a ABS stop while on the dyno and it malfunctioned
Old Mar 31, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: Vacuum question
The check valve is mid way between the intake manifold and the brake booster, and its not visible from the outside. but you can feel it if you squeeze the hose
Old Mar 31, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Re: Vacuum question
I'm turbo, w/ abs, & I have my vac manifold just like that.
I have no abs light, turbo works fine, brake pedal is fine, & no vacuum problems?
What do you mean by compressor surge?
Old Mar 31, 2008
Rufus's Avatar
Re: Vacuum question
I think we figured it out at lunch. You're right about the check valve. The guys suggested removing the check valve from it's current location and putting it before the vacuum block.
Old Mar 31, 2008
Rufus's Avatar
Re: Vacuum question
Without enough vacuum to get the BOV to open the excess air is released back through the turbo, which can be very bad for it.
Old Mar 31, 2008
andyman97's Avatar
Turbo Guru
Re: Vacuum question
Yeah, you want the vac manifold sourcing vacuum directly from the intake manifold. Those guys should know that....
Old Mar 31, 2008
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
Re: Vacuum question
THe way i understood compressor surge is that when the throttlebody closes and there is to much pressure between the turbo and the TB and the pressure doesnt have anywhere to go and it tries to go back out the turbo which causes the compressor blades to spin the wrong direction. It can be bad cause when the Tb is opened again the turbo will try to spin the right direction again and it can stall the turbo and possible hurt it. Thats why you use a BOV to try and eliminate compressor surge. I think it can also be caused when the BOV is too small for the turbo and it cant release enough of the pressure. Forgive me if this isnt right its been a while since i looked this up and im still on pain killers from my surgery.
Old Apr 1, 2008
andyman97's Avatar
Turbo Guru
Re: Vacuum question
That's pretty much it. Boilermaker snapped his shaft from using a shitty bov.
Old Apr 1, 2008
FoSho's Avatar
Re: Vacuum question
oh ok.....so it's the BOV not doing it's job........learn something new everyday! I'm glad dezod supplied me with an awesome BOV.....I don't think I'd ever have to upgrade
Old Apr 1, 2008
Rufus's Avatar
Re: Vacuum question
Well I thought I'd at least try their suggestion and move the check valve to the other side of the vacuum block, although I coudn't logically think of a reason why it would work any different, and it didn't change a thing. I'm going to try Andy's suggestion and T off the vacuum line above the brake booster vacuum line on the IM.
Old Apr 2, 2008
Rufus's Avatar
Re: Vacuum question
So the "check valve" that Honda had in there wasn't really a check valve.. I could see right through it.
We put a regular check valve in and the brake assist is back. The BOV is opening but I think it's just a shitty one. I'm ordering a Greddy.
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
Martinez8o5
Jul 31, 2015 10:58 PM
silentz
Jul 9, 2015 08:16 PM
