For those on K-Pro
Old Feb 24, 2008
Rufus's Avatar
For those on K-Pro
Since we were doing my timing belt yesterday, we put the cam gear on for K-Pro. Since the cam gear is meant to work with K-Pro itself, we installed that too. So as of now, I'm running K-Pro on a 100% stock engine.... for now.
Right now the green key for the immobilizer flashes constantly when I drive. I can only assume K-Pro allows the car to start but doesn't tell the unit in the ignition that a valid key is inserted. My tuner said to take the clamshell apart and inplug the green plug to turn the light off, however that means I have no immobilizer running at all....
Anyone know a better solution to this?
Old Feb 24, 2008
andyman97's Avatar
Turbo Guru
Re: For those on K-Pro
Yeah, have the immobilizer reset at a Honda dealer. Make sure to bring all of your keys.
Also, you need to bring a laptop with you. In KManager, there's a selection in parameters which is to enable/disable the immboilizer. Right now it isn't working. When you get to the dealer, you need to hook up the laptop and turn the immobilizer back on, then they can reset everything with all of your keys.
Old Feb 24, 2008
Rufus's Avatar
Wow, I have no way to get this done without hitting up the dealer?
Old Feb 24, 2008
andyman97's Avatar
Turbo Guru
Unless you have the tool that the service dep't. uses.
Old Feb 24, 2008
Rufus's Avatar
Bummer.
Old Feb 24, 2008
skipbarber's Avatar
HDS (honda diagnostic system). If done right, you should only need 1 key. you are programming your ecu to your keys, not your key to your ecu. I went up to a service tech at a local honda dealer and offered him lunch money (a nice lunch..) in exchange for programming my ecu. he agreed but i never went back. lol..
Old Feb 24, 2008
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
Mine does not flash, but I honestly don't recall how I corrected it. I think I may have cut the wire LOL
Old Feb 24, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
I did mine a couple of months ago that lite can be really annoying.
It's not hard to do I suggest you goto hondata's website they have a step by step walk through on how to do this. Save this to your laptop and then go into the dealer ship to get this done. They will probably tell you that you need all the keys but you really don't cause your recoding the ecu like edwin said.
It doesn't take long but it can be a pain to explain to a honda service tech.
Old Feb 24, 2008
Rufus's Avatar
Ya and I need an RSX o2 sensor apparently as my tuner was worried my d17 one could damage the ecu?
Old Feb 24, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
To use narrowband O2 sensors you gotta move the primary O2 sensor to the secondary input... see hondata.com
We're currently working on the Honda wideband conversion. Its fairly simple, but there is a little work involved.
Old Feb 24, 2008
bomerman19's Avatar
Uhhhhhhhhhhh?
your d17 o2 sensor will not damage your ecu. Just wire your ecu up according to hondata's website and make sure your tuner clicks the "Use secondary o2 input for closed loop operation" box otherwise he will be fighting with it left and right.
Old Feb 24, 2008
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
there is a way to get rid of the flashing green light
Old Feb 25, 2008
ragingSPAM's Avatar
I just burnt my tongue
i've seen it on different cases where kpro left the light blinking and sometimes its off...its an option on the kpro software but it doesnt work all the time...most of the time i've seen it, it has turned the light off...im running kpro but no immobilizer keys in my 93 sedan so i wont be able to give u a better answer than what my tuner told me
Old Feb 25, 2008
andyman97's Avatar
Turbo Guru
Originally Posted by bomerman19
Uhhhhhhhhhhh?
Be careful with this, there are a few different scenarios where this works and doesn't. You have to use a certain map for this function to work with a secondary narrowband for closed loop feedback. Let me do a quick writeup, lol.
Old Feb 25, 2008
bomerman19's Avatar
^ oh sorry I figured since he was running an 03 that he wouldn't have a problem with this and he would be using the narrow band maps only.
My Bad
Old Feb 25, 2008
andyman97's Avatar
Turbo Guru
Yeah, just read the thread about kpro and o2 sensors I just wrote up, it explains how everything works.
Old Feb 25, 2008
Rufus's Avatar
Will do. Gracias Senior
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
Tomj333_EM2
Engine Swaps
Aug 26, 2009 12:28 PM
TransformedBG
Nov 16, 2007 10:00 AM
EM2typeflex
Jul 11, 2006 12:06 PM
