Oil feed tube length
Old Feb 19, 2008
Rufus's Avatar
Any clue on the length of yur tubez? I need to get one this week and I'd like to see if you know the length of yurZ.
KTHXBAI
Old Feb 19, 2008
sl33pyriceboi's Avatar
Re: Oil feed tube length
uhhh oh.....someone double posted!
shame shame....you know better!
=] jk
x2
Old Feb 19, 2008
speedfoos's Avatar
Do what? Are you talking the feed line for the turbo?
Old Feb 19, 2008
Rufus's Avatar
Ya, my last step in geeting prepped for my install are my lines. I plan on getting a Barb fitting (¾ id) Threaded w/nut to tap the pan, but now I need info on what lines I need to run for oil (length, etc).
Old Feb 19, 2008
speedfoos's Avatar
Give yourself about 3.5 feet to get from the back of the block by the oil filter to the turbo for the feed line. The return completely depends on your setup, the actual hose part of mine like 5 inches long. I'd just go with 1/2" ID fittings for the return (which is the same-ish as -10AN), that's plenty big.
Old Feb 19, 2008
Rufus's Avatar
Is yours all steel braided?
Old Feb 19, 2008
speedfoos's Avatar
The feed line is steel braided -4AN line and the return line is now just straight rubber since I messed up all my -10AN braided line.
You can use either. As long as the psi rating is good to go, the rest is just looks. Straight rubber is easier on the hands during install, that's for sure.
I bought a kit for mine from fast-turbo.com. Decent enough, but you can save half the cost buy going to home depot and getting the the stuff if you aren't going to use -AN fittings.
Old Feb 19, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
I would use braided stainless or crimped hydraulic fittings for the feed. I wouldnt trust hose clamps with the heat, and if that line goes, you'll have a fire on your hands.
Old Feb 20, 2008
andyman97's Avatar
Turbo Guru
Isn't that the point of the bling fire extinguisher though?
Old Feb 21, 2008
Rufus's Avatar
I <3 bling
GotSiR
Jun 23, 2016 04:06 PM
brags
46
Jan 7, 2016 09:39 PM
emich
Dec 11, 2015 12:20 PM
carid
Nov 7, 2015 01:46 AM
jessica19699
Jul 29, 2015 05:51 AM
