Ex Engine Swap Need Ecu Help!!
Old Feb 18, 2008
hondarocks's Avatar
hondarocks is an unknown quantity at this point
Ok This is What I have I just swaped my non vtec lx engine for a vtec ex
I have an ecu but honda says that the only way I can get it to run is to buy a new ecu and new keys. So I guess what I'm asking is. Is there anybody on here who has done a complete engine/wiring harness swap. And if they have been able to get it to work with a used ecu. any info Please
Thanks
Old Feb 18, 2008
greeen01civic4d's Avatar
Re: Ex Engine Swap Need Ecu Help!!
yes, u can use a used ecu, but u have to get the key reflashed, like 180 bucks at honda, and u have to get an ex harness too, and it makes a difference between if u have a manual or automatic... there is an easier way however, all u have to get is the apexi VAFCII, a vtec controller, and do the "headswap" diy for it, its not hard, but much cheaper than the ecu and harness
Old Feb 18, 2008
https://www.civicforums.com/forums/1...tion-info.html
https://www.civicforums.com/forums/1...stall-1-a.html
https://www.civicforums.com/forums/1...stall-2-a.html
Old Feb 18, 2008
https://www.civicforums.com/forums/1...p-ex-vtec.html
Old Feb 18, 2008
hondarocks's Avatar
Well thanx for the reply I already installed the harness it came with the engine and it was for a manual trans like mine the ecu is for a manual as well but the ecu is out of an hx vtec is that going to be a problem?
Old Feb 18, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
yes it will. the hx burns lean vtec
Old Feb 18, 2008
hondarocks's Avatar
That SUCKS i guess I need an ex ecu then right?
Old Feb 18, 2008
yes, and its gonna cost u to get it reflashed, and ur gonna have to tow it to honda to have it done
Old Feb 18, 2008
hondarocks's Avatar
Ok let me see if I get it all so what I need to do is buy a ex ECU install it then tow it to honda and get the KEY reflashed not the ECU. Am I right or not. boy you think that jackass at honda would have told me that when I talk to him on the phone.
Old Feb 18, 2008
hondarocks's Avatar
well thanx for all the help guys it was much needed
Old Feb 18, 2008
yea, key has to be reprogrammed for the ecu
Old Feb 18, 2008
Envy's Avatar
Diamond Member
good luck! and maybe you can sell that hx ecu.
Old Feb 20, 2008
andyman97's Avatar
Turbo Guru
Holy cow.
Let me clear some things up. You don't HAVE to have an ex harness for this swap. You also don't HAVE to tow the vehicle to the dealerhsip. You can run on the non vtec ecu with a CEL and swap the ECU's once you get there instead of spending 100+ on towing costs.
Also, you aren't programming a key. You're programming the immobilizer to work with your key and your ecu together. When things are changed where the immobilizer doesn't recognize them, it has to be reprogrammed to accept them.
Old Feb 20, 2008
hondarocks's Avatar
Originally Posted by andyman97
Holy cow.
I am very greatful for the information the only reason I put the EX harness on
is beacause it came with the engine and I probably will drive it up there on the old ECU But I get free tows any way because my cousin is a truck driver
Thanks for the info
Old Feb 20, 2008
andyman97's Avatar
Turbo Guru
Nothing wrong with the EX harness. It makes life easier, just saying you don't have to spend the money on it if you are savvy with wiring.
Old Feb 21, 2008
d17civickid's Avatar
d17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of light
here is a way to go from lx to ex with simple wiring... when i get the parts for my ex head im probably going to be the 1st to try it unless someone else does.. just in case anyone was wondering
https://www.civicforums.com/forums/3...-ex-setup.html
Aball93
May 16, 2015 10:11 AM
cloudguy
Apr 28, 2015 05:02 AM
shawe90
Apr 14, 2015 07:10 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
