Trying to boost my D17A1 Civic
Old Feb 17, 2008
Civicbooster521's Avatar
Civicbooster521 is an unknown quantity at this point
Hey wats going on this is my situation. I got a 2002 Honda Civic Lx Non Vtech and i wanted to drop a turbo on it and just basically run like 6 to 7 psi. Would like to know if injectors would have to be changed and if so wat are some good injectors to upgrade to from factory that would drop right in? Spoke to a couple of people and i was told that injectors from and acura rsx would work. And wat is a good piggy back to use for this set up.
Old Feb 17, 2008
andyman97's Avatar
Turbo Guru
Re: Trying to boost my D17A1 Civic
Wow, these questions have been answered at a minimum of 100 times. Try searching.
Old Mar 19, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Use injectors from a Sea-Doo, they rock!
Nah just kiddin, DON'T DO THAT, I don't even know how sea-doo's work.
The real answer is yes, you can find it by searching. If you choose not to do so, yo can find the information in the following paragraph, but first, here is a story about a boy who cried wolf, there once was a boy who cried wolf! SIKE that would suck if I made you read a long *** story before I told you the answer to your question. The real answer is, a popular choice is you can use the RSX type-S injectors, which work well, but have a limitation on how much fuel they will deliver. Another choice is the Dodge SRT-4 Injectors, they can deliver more power but you need a good engine management for them to idle correctly at lower RPM. And then there's this new injector of some kind I read about recently, I think dezod.com is the only place carrying them, apparently they're better. This is all information that I've gathered by reading past threads etc. There's a lot of info out there.
Old Mar 19, 2008
Rufus's Avatar
Sea-doo FTW!
Old Apr 7, 2008
dezod's Avatar
7thgen Power Maker
Check this out:
https://www.civicforums.com/forums/7...rbo-posts.html
PM me if you need help.
Old Apr 8, 2008
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
wow no one picked up on the "Vtech"....you guys are slippin....gotta go make a phone call now with my "Vtech" phone
Old Aug 22, 2011
sage10's Avatar
sage10 is an unknown quantity at this point
I have a 02 Honda civic lx automatic that I'm currently turboing. What tuning programmer should I use to make sure it doesn't run lean?? And what can be done to keep the automatic transmission from messing up??
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
eXNBP
Dec 9, 2001 12:32 AM
dubbc
Nov 7, 2001 02:24 PM
Boosted
Nov 7, 2001 09:41 AM
pimpdakota
Aug 22, 2001 07:01 PM
