Hondata ECU Hybrid Racing Wiring
Old Jan 29, 2008
Kore's Avatar
Kore is an unknown quantity at this point
Hi everyone
I got a simple question, I'm installing my k20 swap and have the hondata and hybrid racing harness and just need to know where you guys recommend pluggin in the
*** "Key-On" wire that goes to an electrical source that's on when the key gets trurned
*** "Con. 12 Volt" Constant 12 volt source
I'll be running a complete sound system by Crossfire Car Audio.
Old Jan 30, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Re: Hondata ECU Hybrid Racing Wiring
I suggest you use the the cigarette outlet for your key-on wire and then just use one of the main (dam i forget what color i keep thinking about stupid british MGB wiring right the moment) I think white wires that powers everything one of the ones that comes like straight off the battery to give your constant 12 volts. I no there is one close by under the dash somewhere
Old Jan 30, 2008
skipbarber's Avatar
you can get both of these sources at the ignition harness. white is constant and yellow is ignition.
Old Feb 1, 2008
andyman97's Avatar
Turbo Guru
Hey man, you wanna help me wire tuck when I do my swap? I could use some good hands to help me rewire...
Old Feb 4, 2008
Kore's Avatar
Thanks skipbarber, I really appriciate your help.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 11, 2015 07:55 PM
dooner24
Apr 14, 2015 07:51 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
