The results from our turbo kits (quantified)
7thgen Power Maker
Here is a quantified list of results and some interesting data. Some might remember the thread I wrote about asking users for some of this data...here it is! Kinda puts an interesting perspective on things.
Boost Level Break Down:
Approx 50% of the users run 5-6 PSI, while the other 50% run 9-17 PSI. That is quite a gap and not one person who participated ran 7-8 PSI on our kit.
Motor Status:
Approx 20% of the users have had a built motors, while the other 80% are stock.
Engine Management
Approx 30% of the users use a GReddy E-Manage
Approx 20% use Hondata K-Pro
Approx 30% use PCS XFC
Approx 20% use the AEM FIC
Transmission:
90% 5 Speed, 10% Auto
Of all of the 5 PSI people on our kit, which includes 1 auto have averaged power from 180-204whp. This 204whp figure is with our PnP Head on the auto.
People with 5 PSI that used the PCS XFC yielded more power than those with the E-manage and AEM FIC. None of the low boosting people with our kit used a standalone, so this is only comparing piggybacks. In order from highest power shown to lowest is as follows: PCS XFC, AEM FIC, GReddy E-manage. This could be like this due to the fact of the XFC using the stock ignition timing, and the FIC having capability to retard timing.
To compare our Race Manifold at 5 PSI, which is meant for high boost, versus our log manifold: Both cars using the same dyno, both manual, both dynojets. The log manifold car made 186whp & 171wtq while the Race Manifold equipped car made 180whp & 167wtq. I would be interested to see these results on the same 2 cars running 10 PSI or more.
Onto the higher boosters!!!!
The power ranged from 230whp to 273whp and boost ranges from 12-17 PSI. A few of the people where on the E-manage, while the remainder where on K-PRO. None of the cars here where auto, used our PnP head or Race Manifold.
The two closest people where 12 PSI and 13 PSI, while the power results where close 235whp @ 12 PSI on an E-manage versus 240whp @ 13 PSI on K-PRO. The results where pretty spot on for what was to be expected, and the 1 PSI difference could be due to dyno difference, altitude, conservative tuning etc...
The most impressive results from the survey came from the same gentleman who dyno'd the 13 PSI mentioned above. He redyno'd at a higher boost of 17 PSI, which yielded 273whp and 265wtq to match.
That is all for now.
Side note:
The power levels achieved per PSI of boost on low boost (5 PSI) is approx 18whp/PSI of boost.
The power levels achieved per PSI of boost on higher boost (12 PSI) is approx 12whp/PSI of boost.
The power levels achieved per PSI of boost on 17 PSI (based off of one customers account) is approx 10whp/PSI of boost.
Why the fall off? I feel this is restricted merely to exhaust restriction in the catback and/or the turbine A/R along with manifold design for higher boosting.
Motor Status:
Engine Management
Transmission:
Side note:
Re: The results from our turbo kits (quantified)
Woah... this is pretty cool. Its nice to see quantified information on turbo kits with regards to psi, management, ect.
I run 7 psi on the street
my butt dyno says 170ish to the wheels....I believe I can still pull a 200whp on the emanage @ 9 psi. If I can get my exhaust done 2.5 back & tune my ignition on emanage........so even though emanage sucks it works darn good for what it costs, especially if ya buy it used
- I'd really like some comparison between the AEM standalone & Hondata...........I know the hondata is of course a more suitable option for a honda. Ya know, being it is derived from honda software....I really like the function of keeping all stock honda features. Even though diagnosising is fun, having no check engine light to direct ya really sucks!
Damn it. I guess I'm going to have to get my car dyno'd at some point at 8 psi just so I can fill the "not one person who participated ran 7-8 PSI on our kit" niche. Good data compilation Paul.
yeah good data indeed, although i have a few notes
first i'm wondering how does the E-manage pulled up so good against the famous K-Pro, not starting a debate as i have red threads covering the EMS vs K-Pro disscusion, but i mean... E-Manage??? damn...
perhaps the K-Pro aren't so benifitial for our cars because we don't actually use alot of function it controls like VTC and I-VTEC... and perhaps a EMS is more suitable for our application, let's not please start a debate but i would like to hear from Dezod...
what turbo you said was in this kit again??? i mean, 300 whp with 20 PSI is something awsome from an off-shelf kit, and that's without porting heads, fitting cams, or equal length manifolds...
great job
great job
Another reason why Dezod is on top of the turbo game for our cars.
Just for a little extra info, the 273whp by Bob (dopese6070) actually peaked at 280.1whp, and maxed out the factory fuel pump. It was then detuned a little bit for safety purposes. With a larger volume fuel pump, it would have yielded higher numbers.
Technical Assistant
Im just curious about something. If the kit talked about is the t3/t4, I have a question.
Why did you choose to go for such a large turbo. Sure, it makes a few more ponies, but isnt the turbo a bit on the big side. I think that with a T3, you guys could have had 170-180 whp on 6-7psi, and it would have been more fun to drive possibly. This is just based on what Ive heard, but if you can clarify this for me, it would be greatly apretiated. Thanks in advance
The latest technology of the t3/t4 spool just as quick and flow more exhaust out which won't be as restrictive as the older t3's such as the t3 super 60 for example.
Technical Assistant
Well if you are comparing the newest t3/t4 to the older t3 im sure it will be different...what if you compare the new t3/t4 to the new t3...I dont realy keep up with turbo technology much so this is all just kinda me contemplating in my head
When I drove Bobs...there was very little turbo lag. And trust me, once the turbo spools, there is no way you arent going to have fun driving it.
haha woot for me!
^ Hey man remember when you where driving my car getting on the freeway and im uuh dude ur going 120, may want to relax haha.
There was a lot of turbo lag before I went with my 3" exhaust. With the setup now it hits a full 17psi by 4000 rpms so it does have some lag but man once it hits full boost it's absolutly insane. If I held WOT in 2nd it would just roast my 225/50/15 tires once it got past 4000 rpms.
7thgen Power Maker
haha woot for me!
Not true. Chris is an auto with our PnP head and is holding ~205whp on 5 PSI
great job
great job
No the results I posted are correct. (based upon the data I received). I also explained for the possible variance.
And I was also maxing out the stock fuel pump. Shawn (my tuner) actually told me with 1 or 2 PSI higher and a new fuel pump I would definatly hit 300whp. I was getting nervous about the stock intake mani tho lol.
what size turbo is this information purtaining to? im running a .58 trim and would like to see how far off this info may purtain to my setup as a guesstimate of hp/ft.lbs.....
The kit costs $$ because a LOT of R&D went into it. I was glad to pay for it because everything is high quality, stainless charge piping, downpipe, tial w/g and bov. This kit is that expensive because everything is good. They diddn't sacrifice quality anywhere. I believe its a Precision Turbo. Not sure on the trim tho.
The kit costs $$ because a LOT of R&D went into it. I was glad to pay for it because everything is high quality, stainless charge piping, downpipe, tial w/g and bov. This kit is that expensive because everything is good. They didn't sacrifice quality anywhere. I believe its a Precision Turbo. Not sure on the trim tho.
7thgen Power Maker
7thgen Power Maker
still don't know the trim and inlet and outlet a/r's, what size wheel, is it DBB?...and as far as quality i pieced together my kit for less then $750, and it includes a garret .58trim,38mm tial wg,hks ssq bov and new tube manifold and still had enough chedda to pickup a used apex safc II, turbo dsm injectors but had to borrow my aem uego wideband from my srt-4 to dial it all in and get the tune perfected......not bashing but i want to see more info since im about to turbo a hatch within the next few months and would like to explore all options...
We have TONS of turbos that we put together for your kit.
Why in the world would you use the sfac on our cars. Being a tuner I see alot of them and they are fine for NA cars, but for aftermarket turbo setups they are about as good as a 2 penny hoe
7thgen Power Maker
