Emanage Blue Need some help
Old Oct 18, 2007
Silverstreak04's Avatar
Silverstreak04 is an unknown quantity at this point
I installed my Emange Blue in the car... I turned off all the maps except for the ignition timing map... its set at -2 from 2500 rpms up to 8000. The problem I have is when I connect the computer to the car i can drive it and it will drive fine till i romp on it. When i do that i go to 6,000 and shift to 3rd and let off after that when i go to cruiseing speed the bucks back and forth what is the problem that Im having do I need to adjust something. Im not on Boost.. Im using stock injectors... the car struggle to pass 3,000 but when it does it screams like hell.
Old Oct 18, 2007
tfnaaf's Avatar
BLDNPSI Mod
Re: Emanage Blue Need some help
not enough info..... why are you pulling timing if your not boosting? And what else is done to the car ?
raymondxcho
Sep 29, 2015 09:00 PM
sccarally
Texas
Sep 27, 2015 03:33 PM
68camerors
Sep 24, 2015 06:18 PM
MamaBear2015
Sep 4, 2015 09:04 PM
