JDM Base K20?
JDM Base K20?
Okay.... This might be a repost but I couln't find any info on this. So what's the deal with the JDM base model K20. The one with the black intake manifold. Is this the basically the same K thats found in the stateside type s? Or is this one of the sorry VTEC (almost non- vtec) found in the ep3?
I wil fix vBPlaza today
Re: JDM Base K20?
The one with the black intake manifold was the ones from the American Base RSX (160hp) and the Silver ones are the engines for the Type S. At least thats what. So to answer your ? its the one also in the EP3 i believe
7th Gen Photographer
Re: JDM Base K20?
Ok... You're all wrong. There was a 2005 "Base" JDM Integra. They began offering a Type S and a Type R. The Type S had the same HP rating as our USDM Type S basically, but in Japan they rate cars by PS not HP. In Australia (where the article below comes from) they rate cars by kW. It came out as 154kW, or 206HP.
Anyway, I'm not sure of the engine code, but that's the JDM Integra Type S. Then there was the Type R which we're all familiar with and it has the K20A and 220PS.
http://www.autospeed.com/cms/A_2505/article.html
Here. Chew on that for awhile.
Re: JDM Base K20?
Guys regardless of JDM or not "The one with the black intake manifold" is the base rsx here in the states, and its also the EP3 here in the states. rated at only 160 ponies.
Re: JDM Base K20?
he's right. there was a thread about it awhile back. In japan all the k's are called k20a and only the type R was 220hp. The type S was 160hp.
thats why if you got a k20a motor from japan you had to double check the stamp on the head and make sure its a 6speed tranny in order for you confirm you have the one thats 220hp.
The japanese type S had 160hp but the lobes in the head were slightly different then the ones from the k20a3, so it wasn't a exact double of the k20a3.
Re: JDM Base K20?
yea.. and i was one of the first people to experiement with it...
here.. read this..
http://www.k20a.org/forum/showthread.php?t=33824
then read this
http://www.k20a.org/forum/showthread.php?t=2969
here.. read this..
then read this
Re: JDM Base K20?
he's right. there was a thread about it awhile back. In japan all the k's are called k20a and only the jdm type R was 220hp. The jdm type S was 160hp.
also look at this
chiquita.banana
Sep 24, 2015 09:42 AM
AffliictiioN
Sep 16, 2015 02:21 PM
