emanage blue communication issues
i just finished installing a turbo kit in my 2002 ex and we were getting ready to tune and for some reason the emanage (blue) will not communicate with the support tool software on my labtop. i am using the original emanage cable with another cable to make it a usb to usb connection. this means i cant drive my car anywhere and i have to go to school and work so i need help fast!
Re: emanage blue communication issues
its the usb converter.... they cause all sorts of problems because the emanage wire has an authentication thingie in the cable, the USB converter doesnt always like to pass that through to the e-manage software. Search back a ways.... some people made it work, I just dont remember how.
1.48??? I dont know... the version in the box is older than the newest version out, so it should link up then tell you to update the software version in the box. There's a map in there, the car should start, I wouldnt drive it hard.
Your issue is in the converter wire. If you know someone with an old laptop that has a serial port... do that.
it starts up fine its at my friends house and i didnt want to risk driving it home, so right now its sitting in his garage. but ill try and find an old labtop. do you think i could get a converter for a 9-pin to a 15-pin connector? my labtop has a 15-pin port
As long as you're running 310s, keep the car out of boost and the e-manage wont do anything but correct for the injectors. You should be fine driving... just rig the wastegate open.
It'll run rich.... smaller injectors are gonna need longer pulses to dump the same gas, so it'll run pretty rich. if you HAVE to drive the car, wire open the wastegate, put the stock injectors back in and drive without the e-manage. If you can wait to fuddle with it, then try playing with the computer link. Thats about all you can do at this point.
oh man, the discounts i get off of dynex
you can also get a dynex brand converter for your laptop too at best buy.
we dont have a best buy where i live
but its getting tuned tomorrow using my friends labtop
so ill just get that converter next time i go out of town just incase i need to change something later on. thnx
so ill just get that converter next time i go out of town just incase i need to change something later on. thnx Thread
blaketippett
May 29, 2015 08:02 AM
Touge
May 20, 2015 10:54 PM
Touge
Ottawa
May 20, 2015 10:53 PM
Touge
Apr 26, 2015 11:59 PM
AlphaInfinity
Dec 19, 2001 09:25 PM
