turbo vacum lines
Old Sep 10, 2007
hillroad's Avatar
hillroad can only hope to improve
turbo vacum lines
for the tsi turbo kit how do you run the bov line and the 3 peice fitting
plase send a pic if you can also ... because i need to run the fitting to a vacume lane also or something so my boost guage works.
Old Sep 11, 2007
Niterider2gen's Avatar
Niterider2gen is an unknown quantity at this point
Re: turbo vacum lines
U sure u wanna do that man. I have the same setup that messed my car up. But I will take pics and send them 2 u. My car is now out commision. Did you use the injectors they send to U. I advise against it. I didn't realize that I should have gone with srt-4 injectors. My car burns coolant and oil. I won't be able to post those pics till l8er on tonite I'm @ work now.
Old Sep 11, 2007
speedfoos's Avatar
BOV line should t into the any of the existing vacuum lines that are coming off the intake mani, except the PCV. Take a look through my build thread and there is another thread about external WG vac line routing that has the info you need. A BOV is a BOV no matter which kit it comes from.
Here:
Vac Line Stuff with Pics
HondaGuy7
Feb 22, 2016 01:00 PM
powman02
Sep 15, 2015 07:38 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
