car acting up
Old Aug 23, 2007
zexpoweredem2's Avatar
zexpoweredem2 will become famous soon enough
car acting up
So i just took off the week well most of it mon-thurs. to install my turbo kit, i installed everything then late last night i went to start the car and it would not start up i disconected the emanage ( blue) with the plug and play harness from dezod, and just used the factory ecu to start the car and the car would not start, found out that it was a blown fuse for the ignition coil i changed the fuse then tried to start the car and it started right up, so then i tried installing the emanage again, but it did the same thing and would not start but keep on blowing my fuse,
I finally disconected the emanage plug and play harness to try to start it and it would not start, come to find out the new fuel pump busted my fuel line that is inside the tank, i fixed that and now the car will start under the factory ecu but not the emanage.
I even have the settings for the emanage set up to what is on dezod's website.
I have ask paul at dezod but im affraid that he might get mad if i keep on calling him all the time with every problem, that's why i thought i would ask everyone if they might know why when i hook up the plug and play harness it keeps on blowing my fuse, does anyone know the wireing diagram for the emanage if so where can i find it at, or has anyone heard of this happenig to anyone else, and if so what did they do to fix the problem.
Thanks for everyones help.
tylerginevan
Apr 27, 2015 12:29 PM
cdt12271
Apr 23, 2015 11:36 AM
Richkid23
Apr 19, 2015 12:53 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
eXNBP
Dec 9, 2001 12:32 AM
