Vacuum line and Oil Catch Can Diagrams
Re: Vacuum line and Oil Catch Can Diagrams
Chris is tellin me to tap into the intake manifold behind the throttle body, is that right?
i think i have it in the same spot your showing and its not working at all. i think i have it behind the check valve as well (not in the right spot)
No offense intended if you took some. I'm just learning how to MIG weld and think I've finally cracked the code on running a decent, low profile, leak-free bead on tubing. From what I've seen what the guy I paid initially to weld my stuff do, and comparing it those welds and my very similar welds, I don't feel so bad about my skills now! It basically confirms that my welder (Paul) is way better at doing this than I will ever be and I'm glad to see that other folks weld like I do.
thanks for the info speedfoos. the pix are very helpful! ive been doing lots of reading on this lately and hadnt really been able to picture how it all comes together
Yeah, I understand a lot more about catchcans, PCV systems, and vacuum routing than I did in August when I first made this thread. I've ordered all my parts to run the split open-loop set-up pictured in the catchcan diagram. I had just been waiting to get my exhaust sorted before plumbing a fitting into it. Should be nice once I install it next weekend.
Glad it could help and thanks to all who've help me reach the level of understanding I have now.
Dave88LX
Jun 2, 2016 03:43 PM
RIPSAW
Nov 6, 2015 04:36 AM
Kyrian
Jun 26, 2015 11:48 AM
SalPal
Jun 3, 2015 03:44 PM
