emanage ultimate tuning help
to start off with i have a few problems with me emange. i took someones base map just to have me something to start off with, and i put all their information in but now i cant seem to get it to export the information from my computer to my emange system. the icon under the communication file ISNT HIGHLIGHTED. so if anyone has any suggestion then i appriciate it. thanKS
also i almost forgot, under the setting where you turn the ignition to the run position to set the min/max setting, my emanage isnt reading anything, the led just blinks red. in the book it says if it a steady red then its recording information but it says nothing about if its blinking red.
Re: emanage ultimate tuning help
I don't have emanage ultimate but I do have the blue. If you are not getting anything to communicate double check you have the right jumper settings. And if that is all correct make sure you have the right com port selected on your PC to connect with emanage.
Thanks Ill Try That. Also I Heard That If Im Running The Rsx-s Injectors Then Im Supposed To Chose The K20a Engine Under The Settings. Does That Sound Right?
NaturalSelectio
Sep 6, 2015 06:59 PM
