installing A/C on k-swapped 7th gen
alright, I have a 2001 lx with a k20a2 swap and no a/c or p/s. i don't care at all about the power steering, but i drive a ton on the weekend and it's seriously annoying to have the windows down the whole time, and hot!
basically, what all do I need to install a/c on my car? i don't have ANY a/c components, mind you. would it cost me a fortune to even do it? i have access to tons of junkyard cars, and really i can get a lot of 7thgen parts. my dad's friend actually ends up with a bunch of salvaged ones. i just really need some a/c.
Re: installing A/C on k-swapped 7th gen
ep3 line from compressor to condensor
then the low pressure side line from the compressor to the firewall is up to you.. you can do it 3 ways
1. custom lines
2. a modified rsx type-s low side line (lets u use the stock lines coming out of the firewall in your civic)
3. ep3 low side line.. (which also requires the use of the lines coming out of the firewall from the ep3)
1. custom lines
97-DX-Lover
Jun 14, 2015 06:07 PM
beveragemp
May 25, 2015 07:11 PM
