Oil Feed Problem
Old Jun 23, 2007
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Oil Feed Problem
ok so I'm moving through my turbo install nicely. I'm using the dezod kit & oil feed line setup w/ a hose off to a block for my oil pressure gauge. Well I discover even this little hose does not clear the intake manfiold. So I say screw the oil pressure gauge for now. I screw the 1/8bsptonpt adpater in and then the t fitting. I put the oil feed line into the side & try to put the stock oil light into the back like dezod says too. That fits but so tight you can't get the electrical connecter on. Anyone got any suggestions?
Xuhme
21
Aug 7, 2023 03:40 PM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
RIPSAW
Nov 6, 2015 04:36 AM
Blazz
Jun 4, 2015 01:04 AM
civiccowboy
Nov 19, 2001 03:44 PM
