Walbro 255lph Fuel pump w/ Install Kit
Old Jun 13, 2007
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
So I see dezods new Walbro 255 Pump & install kit. Does this kit work without a return conversion? Otherwise, work with stock cars returnless style system? Bolt in & go?
Old Jun 13, 2007
ronaldo9's Avatar
Re: Walbro 255lph Fuel pump w/ Install Kit
Correct you do not need a return fuel system for it to work but you can make a return system with the fuel pump later down the road if you choose.
Old Jun 13, 2007
FoSho's Avatar
Awesome, thanks man!
Old Jun 13, 2007
skipbarber's Avatar
no real sense in upgrading the pump without doing a return conversion to begin with.
Old Jun 14, 2007
FoSho's Avatar
One piece at a time. The kit build up gots me tapped out already
Old Jun 14, 2007
dezod's Avatar
7thgen Power Maker
Not true. Great investment on ANY boosted car. Less stress on the injectors. I have quantitative data on a tC regarding this.
Old Jun 14, 2007
skipbarber's Avatar
ok, you have to be damn near maxing out your injectors to benefit from this without doing a return conversion. i dont see why people dont give the stock pump enough credit. stock pump or not, the stock FPR in the tank keeps the pressure from rising. ive had an idling turbo tC get the purge switch stuck wide open on my snap-on fuel pressure gauge while calculating fuel rail pressure, dump out a few quarts of gas in about 30 seconds and the car didnt even flinch. realistically, the stock pump is more than capable of feeding the stock injectors and evidently can feed the RSX-S injectors to 100% duty repeatedly without failure. that being said, im convinced that even if i ran a return conversion at stock fuel pressure, the stock pump would be more than capable of running the car at full tilt. the only reason i plan on changing mine is because im going to bump up pressure and return fuel to the tank.
Old Jun 15, 2007
dezod's Avatar
7thgen Power Maker
We deal with and create more turbo tCs than any other company around. As a result, we have had a lot of variations in kits based upon customer's demands. Ok prime example was my customer D in Miami. We set up his car with a kit, and I tuned it. At 8 PSI, the 550cc injectors (stock 340), on a 54 Trim .63 A/R turbo, the car made 260whp and required about 6-9% more fuel over stock in the e-mangle additional injection map. We tuned his car for 10, 11 & 12 with, without an open cut-out and methonal....We install a Walbro 255 in his car and the same tune for 8 PSI tuned to 11:1 was not sub 10:0 with no return fuel system at all! Stock PCM controlling the 3 BAR fuel system. So after retuning, he need 0% more fuel because the pump was struggling. EOS
Old Jun 15, 2007
skipbarber's Avatar
ok, so based on your experience with that tC running injectors that flow 210cc's over stock, youd generalize it and say it that upgrading the fuel pump will have the same effect on a boosted civic going from, what? 240cc stock to 310cc? as it does on a boosted tC?
Old Jun 16, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I agree that its cheap insurance to upgrade the pump but the RSX uses the same pump as in our cars, the turbo k20s making more than 250-275 typically upgrade after that point. The factory RSX pump is more than capable of maxing out the stock RSX injectors. If someone is running a piggyback with rsx injectors and a stock fuel pump on a turbo D17 they are going to be ok at a 200-220 whp level IMO.
Old Jun 16, 2007
skipbarber's Avatar
thats all im trying to say.
Old Jun 17, 2007
dezod's Avatar
7thgen Power Maker
For one it's cheap insurance and a sake of mind. For less than $100 you rest assured to have consistent, non-falling-off fuel pressure and not worry about maxing out the pump.
Wilmnchris, the 170whp auto that had our PnP head and made over 200whp.....he was having fuel supply issues from the stock pump on the car with just 170whp!! The tune became significantly rich after installation, which was a great sign due to the fact of adding the pump and supply of the fuel staying full blast under the entire RPM band. Most of the OEM pumps are designed to ween pressure down some as the RPMS rise.
Once again, if your shooting for a hard driven 175whp+ car, WHY RISK IT FOR JUST $100!????! If you have $$ to boost, but can not afford a $100 pump, you should not be boosting. And I will quote:
"If you can not afford to drive your car off a cliff, you should not be boosting your car..."
Old Jun 18, 2007
speedfoos's Avatar
Crap.
So who wants to buy my turbo stuff?
Old Jun 29, 2007
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
hhey is there diy for the install. i just got mines and i own a turboed 04 ex coupe... how hard is install?
jammer48
Oct 4, 2018 10:04 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
beanhead
Sep 24, 2015 12:04 PM
pilebuck13
Sep 21, 2015 10:45 PM
thaler4cuse
Sep 7, 2015 08:25 PM
