k-swappers w/a/c....
Old May 27, 2007
kornsined's Avatar
I have a question for K-swappers with a/c.
I have my lines all hooked up but the original d17 connection for the compressor is different then the k-series one. I rewired it but now the a/c stays on constantly. I wanted to know how others got around this problem.
Here's a pic of the connection:
d17,#5
RSX,#5 as well
Old May 27, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Re: k-swappers w/a/c....
You are using the k--series compressor right?
Old May 28, 2007
kornsined's Avatar
yes I am. The rsx connection has 1 wire and the d17 one from my harness has 3 wires.
Old May 28, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
uhh... no.. mines has one...and the other 7thgen that i did the swaps in were all 1 wire... i think you got the wrong wire
if you look at your D17 and the K20 compressor there both 1 wire
Old May 28, 2007
kornsined's Avatar
no I actually looked at my old engine and seen the connection on the compressor. 3 Red wires on the connection to the compressor. On the wiring harness end there is a blue/white, blue/brown, and red wire.
I have no idea if this is something different with canadian models.
I was also thinking if the a/c condensor fan comes on when I hit the a/c button then I could tap into that line to turn the compressor on instead of the current hook up I have now.
I'll try and take pics.
Edit: I found this. I'll have to PM him
Originally Posted by MrXclusivE
different years and models might have different part numbers for the AC compressors, this doesnt mean it won't fit a different year car, the only difference could be in the top part where the electrical connectrions are, which is easy to modify, just cut and resolder the wires, I bought one off a member here last year for 50$ cuz mine broke, dealer charges 900$!! hope this helps
Old May 28, 2007
What wire harness did you use?
Old May 28, 2007
that funny.. cause i changed comprssors from all years from 01-05 and dx-ex and they were all 1 wire. I think its just a difference between US and canadian
Best way to figure it out. Get a light tester or a multimeter if you have one. turn the car to on but dont start it. Make sure the a/c light in the car is off. Put one end of the tester to the ground on the frame of the car and then touch each wire. If the tester lights up then you dont use that wire.
When you find one that doesnt light up. Go back into the car and turn the a/c button on. Then go back to the engine and touch the same wire. If it lights up then you just found your wire
Old May 28, 2007
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
mine has 1 wire.
Old May 28, 2007
No i know what your problem is... i just have to remember how i fixed it. My friend had the same proble, with his A3 swap..., 2 of the wires go to the something else... and i think they get looped around. I know this isnt making since, but i had the same problem.
Old May 28, 2007
funny cause trying to figure out why in a very rare instance that some people have a 3 wire??
because the compressor only needs a power signal... to turn the clutch on and off. Well at least the 1 wire comressors do
as long as he finds that one wire that turns power on and off when he pushes the button he will be fine
Old May 28, 2007
What are the 3 wire colors.. i can tell you what i what i did..
Old May 28, 2007
HondaLuver's Avatar
Its a celebration bitches!
ac is for pussies
Old May 28, 2007
Originally Posted by HondaLuver
ac is for pussies
You calling me a *****? Ill play with your k24 any day!
Old May 28, 2007
kornsined's Avatar
one wire is solid red, one is blue with a white stripe, the last one is blue with a brown stripe. See I did what you suggested, I hooked up one wire at a time and the only way the a/c worked was when the blue/white wire was grounded and the one of the other two (red or blue/brown) OR both red & blue/brown were hooked up.
It works but the a/c doesn't turn off. Doesn't matter if the a/c button is on or off.
Old May 28, 2007
HondaLuver's Avatar
bring it on *****... lol
i'll be waiting here, just gimmie a few days advance notice..
Old May 28, 2007
well i know this may or may not help.. But this is how it goes
Old May 28, 2007
Ide suggest right clicking on it and viewing the image location
Old May 28, 2007
kornsined's Avatar
n/m.....I'll check it out
damn, I need a d17 one to compare.
So what I'm getting is I have to wire the blue/white to the blower motor relay, the blue/red to the a/c compressor, and the red to the ACC in the ECM....
Where is the ECM?
Old May 29, 2007
have you tried connecting the blue/red wire to the a/c and try turning it on?
Old May 29, 2007
well yeah in a nut shell... i havent been able to get a hold of my friend. whom we did. but he had the same problem and i seriosly cant remember, but i remember that diagram
Old May 29, 2007
kornsined's Avatar
yeah I did, the a/c won't come on unless the blue/white is grounded.
Old May 29, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
I suppose if all else fails you could wire up an aftermarket switch to power it on and off?
Sorry this is off topic but I am going to be hooking up my AC in the next little while. Which combination of AC Lines did you end up using that worked well? Or were custom ones needed?
Old May 29, 2007
kornsined's Avatar
custom ones for me. the ep3 lines work if you have the ep3 engine. the p/s pump gets in the way on the rsx engine.
Old May 29, 2007
actually you can still use the ep3 with the rsx engine.. you have to slightly bend the metal part of it that comes in front of the motor about 1/4 - 1/2 inch to the right and it clears perfect
Old Jun 1, 2007
kornsined's Avatar
Anyone with the helms manual for the civic coupes want to copy this diagram for me?
Old Jun 1, 2007
i think that is the coupe diagram.. if you look at the compressor clutch.. only one wire is going to it.. thats how most of our cars here in the states are.. just one wire runs the compressor
Old Jun 1, 2007
Basically that pick is how its supposed to look i got a coupe.. ill douple check for you.
Old Jun 1, 2007
kornsined's Avatar
yeah I checked the Honda Electronic Service Manual that I got off of here a while ago and it doesn't have the heating/cooling section. I just wanted to double check.
Thanks Xproductionz and TransformedBG for the help.
Old Jun 1, 2007
HondaLuver's Avatar
i can't wait till i get ac again in a month
Old Jun 2, 2007
kornsined's Avatar
screwed around with this some more with no success.
I found out some new info. The red wire comes from the A/C pressure switch. So on the a/c pressure switch a blue wire goes in like the diagram except a red wire comes out and on the old d17 compressor it would attach to the thermal conductor.
The blue and white would also connect directly to the thermal conductor, while the blue/red goes directly to the field coil.
I'm kinda stumped. Anytime the wiring is wrong my condensor fan comes on never shutting off and my engine idle will hang high around 1800rpms.
