New dyno numbers SHOCKING! NEW VIDEO AND PICS on pg 7
Old May 21, 2007
  #61
dezod's Avatar
7thgen Power Maker
Re: New dyno numbers SHOCKING!
Originally Posted by andyman97
Just goes to show, no matter how much you spend, when you make power, **** breaks.
That is how you gauge if your making good power or not. If you are, your breaking ****....if not, your not tring hard enough.
Old May 21, 2007
  #62
andyman97's Avatar
Turbo Guru
^This is why I have so much downtime, LMAO!
Old May 22, 2007
  #63
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
The clutch was working fine on the streets but when I push the car hard i could tell it was about to go.
Paul can you get the axels?
Ball joins?
Old May 22, 2007
  #64
dezod's Avatar
7thgen Power Maker
Ball joins?
Axles....try Driveshaft Shop or Gator Grip. Those guys may be able to put something custom together for ya.
Ball joints, lemme see........I will get back to ya.
Old May 22, 2007
  #65
tfnaaf's Avatar
BLDNPSI Mod
Ball joins?
I've read somewhere that aftermarket ball joints are available...... checking now
Old May 22, 2007
  #66
tfnaaf's Avatar
BLDNPSI Mod
Yup moog part number K90332 fits 01-02. I can buy them for $48.62 each wholesale pricing. Cheaper than the knuckle set-up from honda. I would think you should be able to buy them locally for the $60-70 range
Old May 22, 2007
  #67
supermex's Avatar
You are absolutely right tfnaaf and very close on the price.
I was having my doubs about it, but my friend from Ventura Racing called one last place Bumper to Bumper about 9:00 am and they had them on stock, delivered by 5:00pm today.
I didn't belive it
I'll find out for sure by tomorrow.
But now
you got the part number and detailed price WTF
I almost got OEM knuckle from Majestic, they had the best price of $260.00 for booth sides.
Moog sounds like a good proven brand so I'll pay 140 -150 delivered to the shop no problem.
YOU GOT SOME REP COMING TO YOU!
Old May 22, 2007
  #68
tfnaaf's Avatar
BLDNPSI Mod
Moog is top notch quality too. I install moog products daily
Old May 23, 2007
  #69
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
yo supermax did you ever instal your lsd
Old May 23, 2007
  #70
dezod's Avatar
7thgen Power Maker
I do not think so, as I have been on Quaife like flies on shhhh about getting this unit done for production. They said they are still 2-4 months out.
Old May 23, 2007
  #71
^^^ do you know around how much it would cost ...also i thought he got a unit that would work... but was waiting on founds to put it in. since he is going to replace the clucth then this would be a good time to put it in.
Old May 23, 2007
  #72
supermex's Avatar
I got the same answer as Dezod
It seems like is going to be ACT stage 4 clutch, gator grip axels and Moog ball joints.
Old May 23, 2007
  #73
dezod's Avatar
7thgen Power Maker
No estimated cost yet. We are #1 on the release info for this unit and will undoubtedly become the master WD for this app.
Old May 24, 2007
  #74
supermex's Avatar
Clutch is installed it was easy going in.
just waitting for the axels to be ready.
I paid extra for the rush order.
Old May 24, 2007
  #75
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Ya know, when I first got my civic, couple of years ago, I would have never guessed that any of this was possible. and yet I am still being impressed by people and manufacturers alike. If you put your heart and sole into your work, then the sky's the limit. All of this is wonderful.
Old May 24, 2007
  #76
supermex's Avatar
I also got these roll center adjusters, if they work, I may use them instead of the Moog ball joints.
They'll be here tomorrow
Old May 25, 2007
  #77
supermex's Avatar
Just work on the car all day at my friends shop and took it for a test drive about an hour ago.
All I got to said is DAAAAAAAAM
Is nice to know that you let go on the clutch at high RPM's without the fear of braking the axels.
That thing is crasy fast, stage 4 slutch is no joke!
It just need an alignment.
I'll do that tomorrow and I'll find out how it handles with the new roll center adjuster set up.
Old May 25, 2007
  #78
Civicman1988's Avatar
where did u get theem?
Old May 25, 2007
  #79
Michalo187's Avatar
Abortion Survivor
^^^^ What do those do?
Old May 25, 2007
  #80
supermex's Avatar
WHAT IS ROLL CENTER ?
While a vehicle corners, the movement of suspension is focused on the intersection (instant center) of the lines extended from the upper and lower suspension arms.
The intersection between the line from where the wheel contacts the road to the instant center (Point P) and the vehicle body centerline is the roll center (Point B).
With the stock suspension, the appropriate roll center has already been set from the factory. (Fig. 1)
ROLL INCREASES AFTER LOWERING?
Simply lowering the car results in an increase in the distance between the center of mass (Point A) and roll center (Point B) of the vehicle, even though the center of mass has dropped.
When the distance between Point A and B increases, roll stiffness decreases, causing an increase in the amount of roll. The amount of roll can be controlled with the use of stiffer springs, but ride quality etc. suffers as a result. Cornering speed does not increase like originally thought. (Fig. 2)
ROLL CENTER ADJUSTED !
With the Roll Center Adjuster in place, the angle of the lower are is revised. Roll center (Point B) is once again close to the center of mass (Point A) of the vehicle.
With the lowered center of mass and increased roll stiffness, the limit of cornering speed increases.
ROLL CENTER ADJUSTER FF
When a FF vehicle is lowered, the angle of the lower arm becomes poor, resulting in a significantly lowered roll center.
Consequently, the amount of roll in corners increase and the cornering force is sacrificed.
By extending the ball joint of the front knuckle, the position of the roll center is altered. Replacing the stock ball joint with this product will result in reduced roll, and cornering force as a result is increased. Steering response is also improved. This product is the long-awaited part for FF vehicles.
Price: CAD $362.00 (USD $329.09)
Old May 26, 2007
  #81
Michalo187's Avatar
Abortion Survivor
^^^ thanks hector, hector what cam are you running?
Old May 26, 2007
  #82
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
those roll center adjusters are some balla ****! I've got those on my civic and rsx and made a world of difference! you should also try out the j's racing spl tie bars for the ep3. it bolts on with no midification. a must if your car is slammed!
props on the badass numbers!
Old May 26, 2007
  #83
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
imagine if he would makeit a track car no subs no interior i wonder what his #s would be 1/4
Old May 26, 2007
  #84
supermex's Avatar
I have my own regrinded cam.
comparable to stage 3
I just got home tired as heck ready to enjoy my holiday.
car is aligned and took longer that I though some modifications to the camber kit and strut where necesary.
I spended a $100.00 on it a good deal concidering the amount of work.
My friends are happy that I work side by side with them and I usualy paid for my parts and I even go get them to speed up the process.
I even helped out with some of the other cars in the shop.
I'm watting to find out how much my labor for the clutch and axels install will be.
I'm sure it will be a good deal.
Old Jun 2, 2007
  #85
supermex's Avatar
I just find out that because of the bad stage 2 clutch I may off missed 10 to 20 % of the power to the wheels when I dynoed last.
I feel more of it when I shift, before when I floored it and the turbo spooled the car moved faster but the engine reved up higher and quicker.
I may have even more HP now than before.
By the way fist kills where an eagle talon on the high way, than a Mustang GT on the street.
The dude on the Mustang was talking shish about all show and no go on the light, then the green light came on then I was gone.
I slowed down because of traffic, he cough up with me, then started to cut me and others off so i just let him go.
It was sweet!
Old Jun 2, 2007
  #86
kasimmmmm's Avatar
bro you HAVE to take the car to the track now and kick some ***! Show us some videos!
Old Jun 2, 2007
  #87
kasimmmmm's Avatar
It was sweet!
Old Jun 2, 2007
  #88
marcuse's Avatar
marcuse will become famous soon enough
my question , whats the bill for your car as it sits.. 20 grand?
Old Jun 2, 2007
  #89
supermex's Avatar
The dyno sheet.
Notice the torque curve so close to the rpm's.
bad a$$
Old Jun 2, 2007
  #90
Michalo187's Avatar
Abortion Survivor
Re: New dyno numbers SHOCKING! Dyno sheet on pg 7
nice!
