K24 swap question
Old May 5, 2007
BigD001's Avatar
BigD001 can only hope to improve
K24 swap question
OK i was planing on slapping a turbo on but my friend changed my mind. My question on the part? heres what i think i need, if you see something wrong please tell me
-CRV engine
-O2sensor for the same type of motor
-subframe from a rsx or si
-Hasport Mount Kit
-Hasport Wire Harness Conversion
-Parts needed from an Base RSX:
-shifter cables
-intermediate shaft
-clutch lines from master to slave cylinder
-high pressure power steering hose
-power steering return line
Parts needed from an 02+ civic si:
-ac line from compressor to condenser
-axles
-radiator and fans
-upper and lower radiator hoses
-tranmission (dont want a 6 speed)
-ecu
Others
-92-95 civic power steering resevoir with bracket
-throttle cable from 92-95 civic
Old May 5, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
Re: K24 swap question
This has been covered. check the force induction forum under 7th gen. theirs a how to write-up in their with a list of all the parts you need. search is your best friend
This is the actual thread
https://www.civicforums.com/forums/7...29-2007-a.html
This is the k20/k24 DIY
http://www.xproductionz.com/k20swap/k20swap.html
Old May 5, 2007
BigD001's Avatar
thats where i got the part list from but its for a k20 not 24 so i wanted to make sure.
Old May 5, 2007
Buds302's Avatar
Buds302 will become famous soon enough
xproductionz writeup explains it all man....read up
Old May 5, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
i dont think you read it... did you even bother readin the first post.. it says so in the first few lines of post #1 under
"UPDATE 1/7/2007 (Slightly Updated)"
Old May 5, 2007
0H3ebpEM2's Avatar
list and DIY applies to both the k20 and the k24. only difference is the k24 needs a different passenger engine mount. Just read the thread thoroughly it explains everything. Read first then ask questions
dbagaus
SOHC D17Ax non-VTEC - VTEC Engine Swaps
70
Feb 22, 2023 04:26 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
codys civic
May 31, 2015 03:28 AM
ClutchMasterOG
May 31, 2015 03:25 AM
viper775
Dec 9, 2001 10:52 PM
