k20 swap 1/4 times
Old May 5, 2007
edrulz2003's Avatar
edrulz2003 will become famous soon enough
k20 swap 1/4 times
i went to the track last night and i ran a 16 with my k20 swap in my 01. Now i believe it was so slow because of my 18" rims. Is this true? i also have full interior with a big *** subwoofer box in the trunk. what do u guys think. I got roasted twice last night once by a 14 sec cobra and again by a 12 sec EVO MR
Old May 5, 2007
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
Re: k20 swap 1/4 times
next time remove as much unneccessary weight and switch to smaller rims before you go to the track
Old May 5, 2007
tougEMII's Avatar
tougEMII has a spectacular aura abouttougEMII has a spectacular aura about
really thaat is way to slow..waaaaaaay slow even if u have all that weight. something is wrong. did u just drop in the swap? and what parts do u have on the swap
Old May 5, 2007
edrulz2003's Avatar
pretty much its just a stock swap...i have no extra parts on it yet.. i have a cold air but not on yet. im 235 lbs and i know my subs way atleast 70 or 80 lbs...like off the line i was so slow but after words i was pulling alot harder..when i raced the cobra he killed me off the line but through the thousand he beat my by almost a sec. well i think its the rims..maybe a lil of my driving...
Old May 5, 2007
lxcivic2k1's Avatar
Thats really slow, even for an a3. stock a2 should be in 14s cause an RSX-S runs a 14.1 or so.
Old May 5, 2007
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
Yes that is very, very slow my first and only time at the track it was hot as hell, my 60' times were horrible (best was 2.45) and I still ran 14.1. I would say that something is wrong with your car. What were your trap speeds??
Old May 5, 2007
tougEMII's Avatar
the slowest u should hit would be 15s. even with a bad driver 15s would be possible. and on 18s ud have more traction. so something could be wrong with the motor. maybe timing is off.
Old May 5, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
You should be in the 14s' but 18" rims will slow you down... cant all be cool like me
Old May 5, 2007
tougEMII's Avatar
^ it shouldnt slow u down to the point of being 2 seconds behind.
Old May 5, 2007
kasimmmmm's Avatar
Depends on your mods BUt i've seen a lot of high 13s.
For other chassis like EGs and EKs, its lower 13s.
Old May 5, 2007
EMK20a2's Avatar
I actually ran a 15.1 one of my passes LOL I completely bogged off of the line, I got beat by a 5.0 that ran a 15.0xx.
Old May 5, 2007
edrulz2003's Avatar
yea it kinda felt like i was boggin down also off the line cause it was slow. My car has the k pro but i didnt have the funds to get it tuned yet so i dont know if that might have an effect cause im sure fuel pressure or timing can be a huge issue. So next week im gonna take my seat out and my system and see if i approve. Is it true every 100 lbs is a 1/10 of a sec.
Old May 5, 2007
D5cIvIc's Avatar
doesn't stock manual civics able to run a 15.7??? yeah something is wrong there man.
do you have an A3 or an A2?
Old May 5, 2007
edrulz2003's Avatar
yea i have the a2..so yea something hs to be wrong but i dont know what..it pulls hard as hell from a roll, just yesterday i beat the new 06 gt...so what do u think..
Old May 5, 2007
TRIZ's Avatar
Shoot, you know theres something wrong with your car if I got an lx w/ i/h/e on my em2, and I could beat your k20 swapped vic... *shakes head* Just got to the tuner- how can you drop all that money on the swap and then not put the money down for a tune? Go to the tuner, if there is something wrong, he'll probably find it in the process.
Old May 5, 2007
EMK20a2's Avatar
^^^Yep, that was my thinking when I was debating spending $400 on a tune. After a bit of thought I came to the conclusion that it would be stupid not to.
Old May 5, 2007
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
yep thats what I did on my A3.. Get your Swap Tuned. and Grab a Race header.
and maybe 2.5" sxhaust.
My k20a3 swap ran 14.9 So something is wrong.
Old May 5, 2007
edrulz2003's Avatar
ok guys so yea i came to the conclusion i need the tune asap to see what my numbers are..I appreciate all ur guys help on answering my question. Im hopin i would of been around the 14.5 sec. but that 1st race diappointed me so bad when it said 16 sec. but thanks and i will keep u posted 7th generationers.
Old May 5, 2007
White0nGold's Avatar
White0nGold has a spectacular aura aboutWhite0nGold has a spectacular aura about
wow thats slow, i ran a mid 14 with my k20z1 swap in my FOUR door 01 civic, withOUT k-pro! street tires, no lsd, not stripped, all i had was intake,TOda race headers,and exhaust, i was faster then a g35skyline, and i forgot what else but yea, 16's? ur making the k-swaps look bad
Old May 6, 2007
tougEMII's Avatar
ok intake, toda race and exhaust makes a big difference buddy. especially for a z1. in fact i think its rather on the ehhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh side that u hit mid 14s. but hey nt.
anyways dont worry he'll be fine once hes tuned. good luck and post up numbers man and go back to the track again
Old May 6, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Its possible you just arent launching properly. Are you just learning how to drive standard?
I know I'd run a shitty time on the QTR mile as well but I am just learning how to drive stick
Old May 6, 2007
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
first time I ran my swap I ran mid 13s all day.. maybe you just need some practice?
Old May 6, 2007
EMK20a2's Avatar
Maybe it had a bit to do with the track, a cobra should be alot faster than a 14sec car.
Old May 6, 2007
edrulz2003's Avatar
yea i dont think it was the track cause they had some fast *** cars runnig what they thought they should be running...
yes this is also my 1st stick car and my reaction time was like 9/10 of a sec i know thats bad but it felt like my car didnt wanna move off the line...so take some of that off the 1/4 and i would be running like 15.6's.. thats still bad but i will imporve on those and get rid of those big *** 18's also.
Old May 6, 2007
EMK20a2's Avatar
I don't think your reaction time is included in your 1/4 mile time. The timer does not start until you cross the line. What were your 60' times those are what you should look at.
Old May 6, 2007
tougEMII's Avatar
i think u should just get tuned right away. no need to see what u can hit especially if ur hitting low. imo just get it to the shop asap. base run, then tuned run, and more tuning runs.
Old May 6, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
hahaha a 16 my current set up would beat u haha....on a real side get a good header, get a 2.5 or 3inch exhaust for the k to breathe, tune a/f in kpro, use the cai kpro map if you are still unable to get a tune quickly and so forth... all of that and you should run mid-hi-13's. you need good tires to, lower the 60ft times
Old May 6, 2007
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
I ran a 16.4 with my 02 ex civic manual with intake header exhaust 35 pounds per wheel 18s and a stereo. It just might be that you aren't launching like other people are saying, what do you drop the rpms at?
Old May 7, 2007
tougEMII's Avatar
^16.4 i/h/e? 60 foot times? please dont say 2.5
Old May 17, 2007
djmota's Avatar
So what was your trap speed? That will be a good indicator if there was anything wrong. You should be trapping in the 90's My opinion is you just don't know how to launch yet. A bad launch greatly effects your et especially if you bog. Slow shifts add more time, not shifting at redline....it all adds up. Keep working at it.
