k20 type R swap in 01 civic ex
Re: k20 type R swap in 01 civic ex
well now that i got the k24 i cant use it... it binds the mount cause the motor sits lower.... if its wheel hop ur worried about then i suggest you get some a-arm bushings put in..
other than that hasport said you dont need it. Asked them a while back when i first did the swap
I Hunt Goats, Rams, And Mustangs.
tsk tsk tsk...searching owns you man.
First of all, as for the ECU, you will use the actually TYPE R ecu or you can use a type s ecu/kpro to make it work. I would use the type S ecu since you can take advantage of the immobilizer function in our cars.
You dash kit, i'm taking as you mean your gauges, can be changed out if you really wanted it. As for me, i'm just changing mine out to the 02 civic manual cluster. You don't need to use the SI CLUSTER, then you would have to go through the trouble of actualyl re-wiring it to work in our cars.
Third, yes you have to switch out the center console part where you automatic shifter sits right now. You would have to order that part around your shifter to adapt to a manual shifter. Its confusing but yes you have to switch out that front part of your center console to the manual one.
Engine mounts can be ordered from http://www.hasport.com/products/mounts.htm
YES TONS OF PPL HAVE DONE THIS. you should really search next time before you post something like this again.
I'm also doing an auto to manual and installing a k20a2 rsx type S motor in my car within the next month.
there is threads on here that states exactly what you need and how to do it. search please
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
mattdoc
Mar 14, 2017 12:10 PM
cloudguy
Apr 28, 2015 05:02 AM
GaryFishell
Apr 24, 2015 06:49 PM
