which option to take tuning my d17
Old Jan 16, 2007
tucks15's Avatar
tucks15 is an unknown quantity at this point
just looking for some help for tuning my turbo d17. ive heard people like the greddy emanage. just wondering what my other options are other than going to a full stand alone system. i dont have an unlimited bank account so keep that in mind. any help is apprecited. thanks guys
Old Jan 16, 2007
tucks15's Avatar
also my engine is none vtec
thanks again
Old Jan 16, 2007
ronaldo9's Avatar
Emanage is one option, also looking into PCS-XFC aka powertrain control systems. I believe there is a plug and play harness available for the d17 for the emanage ultimate so that will be another option instead of emanage blue. IMHO aem ems > PCS-XFC > emanage ultimate > emanage blue > tsi fuel system > vafc/safc 2.
Old Jan 16, 2007
Civicman1988's Avatar
AEM its expensive but u cna do anything on it
Old Jan 16, 2007
tucks15's Avatar
thanks for the help
are all those options usable without vtec, ive heard that apexi's are not. is this true. thanks
Old Jan 16, 2007
ronaldo9's Avatar
You can use all of the above w/o vtec except VAFC2 sorry I didn't mean to confuse you. Instead use an SAFC2. If you ever decide to get a head swap off an EX you can use a VAFC2 though.
Old Jan 17, 2007
exturbo6's Avatar
call up paul at dezod and talk to him..
i wouldnt get e-manage. look into the pcs...or aem ems if u wanna send the money. the more options u got on the tune the netter ur car will come out.
Old Jan 17, 2007
tucks15's Avatar
hey guys
i have found a guy that has a apexi safc here in town. it is not an safc 2. will this work. i went to there website and they dont have a wiring diagram for an 01 civic. could i make this work? thanks
Old Jan 17, 2007
ronaldo9's Avatar
SAFC 2 is what you need. I'm not sure if the first version is compatible.
Old Jan 21, 2007
tucks15's Avatar
im looking at an emanage right now but if im only gonna be running 6-8 psi do i really need an upgraded fuel system and upgraded injectors for that?
Old Jan 21, 2007
ronaldo9's Avatar
Yes that is ABSOLUTELY necessary. The stock fuel map is only good for like 3psi if that. You need larger injectors like rsx type s to be able to run 6-8 psi.
Old Jan 21, 2007
tucks15's Avatar
hey man thanks for your help. it is much appreciated
Old Jan 21, 2007
skipbarber's Avatar
as much as people dog the emanage..i must say that for the money, it really isn't a bad system. it honestly does it's job, the only thing that's really out of reach for it is partial throttle boost and vtec. you don't have vtec, so that cancels that out.
Old Jan 21, 2007
C2i0v0i1C's Avatar
SuperMODrizd
i severely advise against the vafc and safc. unless the newer versions have drastically improved their scale of tunability they are not going to do what u need. when i first started my adventure. the intervals and rpm ranges of those two were very broad intervals. where as with other systems u have the ability to tune more precise at a distinct rpm range and intervals
Old Jan 21, 2007
tucks15's Avatar
hey i am just about to order my emanage from dezod but i was wondering what sensors i need to also order it i plan on turboing my car. thanks
Old Jan 22, 2007
ronaldo9's Avatar
Boost pressure sensor and harness is a must along with the main harness, ignition harness, and injector harness. If you by his plug and play harness it will already have th injector harness and ignition harness. Just PM dezod or speak to him before ordering and he will tell you everything you need to have.
Old Jan 22, 2007
civic01vtec's Avatar
I've been running 8-9 psi for over 3yrs and 30,000 miles on stock injectors with no problems.
The injectors have nothing to do with boost, it is about how much hp you are making. The stock injectors are good for up to about 185whp.
UltraHDGames
Jun 8, 2016 05:16 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
General DIY
Sep 25, 2015 08:02 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
