boosted k20a2 hondata question
Old Jan 7, 2007
LXracer's Avatar
LXracer is an unknown quantity at this point
Exclamation boosted k20a2 hondata question
So, i know that u cant trust the hondata maps that are included with the unit because they are just a base and is not 100% correct for every car. My question is simple but i just want to make shure that this will be ok for about a week until my appointment at the shop to get dino tuned comes.
turbo kit background: the kit i got was one a friend makes and sells on ebay with a 45 trim t3/t4 turbo and a FMIC ( 20X9X2.75" CORE )
the question: Can i use the K20a2-RSX-440cc-16hm-Greddy=7psi-kla as
a map untill tune???
the reasion i am asking is beacuse right now i am useing the
k20a2-rsx-310cc-todahdr wich is the map for toda header, intake, exhaust, and stock cams. The only diffrence is that i have a DC header but it works with no problem. Now, i have 310 injectors that run at 43lbs of flow. the 440s also flow the same. If i go into hondata and chage the fuel trim from 440-310 will the car still run the same? All of the other parameters are the same in both maps exept Vtec wich is setup to engauge at 3000rpm (upper and lower bounary) with the N/A map and 5800rpm upper and lower with the turbo map. The other small change is the Rev limit decreaces on the turbo map from 8600-8100rpms.
Please respond because i dont want to distroy my engine. If there is more i would need to do or if there is a better way to go about tuneing until my shop date let me know because the civic is my DD until my tallon is finished. Feel free to PM or IM me on AIM if u have any ideas THANKS SOO MUCH GANG!!
-CRAIG
Old Jan 7, 2007
LXracer's Avatar
any one....PLEASE
Old Jan 7, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
can u kinda format it so i can understand the question you are asking better... lol
sorry.. kinda half awake and half asleep.. lol..
Old Jan 7, 2007
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
basically, he wants to know if he can use a base map tune for his turbo setup until he gets to the dyno.
My oppinion without even knowing the setup is not a good idea but you will do it if you want. Couldn't you just pull the WG spring so it doesn't make boost and drive it like that until then?
Old Jan 7, 2007
HondaLuver's Avatar
Its a celebration bitches!
put it together, make sure it runs, don't drive it around till the tune... better safe than sorry
Old Jan 8, 2007
LXracer's Avatar
will that wg thing work????
Old Jan 8, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Yes, the wastegate trick works. If its open, then the exhaust bypasses the turbine (path of least resistance). You make no boost. But I wouldn't bury the gas pedal either.
Turn it on, make sure the car runs and limp it over to the tuner where it can be mapped.
kmarcet
Sep 26, 2015 10:25 PM
martinsmartin
Aug 15, 2015 07:34 PM
JDMnoob
Aug 2, 2015 02:38 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
