Max HP from N/a D17?
Old Nov 23, 2006
Mike04Civic's Avatar
Mike04Civic is an unknown quantity at this point
Question Max HP from N/a D17?
So I'm working on building a block/head for turbo setup. Ive got a DX, but recently purchased an EX head so that i can get cams/valve-train etc.
My question is, what is the most horsepower I could get from my engine with the head-swap ( assuming i got a cam, cam gear, and the Apexi vafc, or w/e its called)? Turbo looks like it would be rather fun to build/drive, but I have other things I need to spend money on. So I might just windup n/a depending on how much HP i could possibly get out of it.
If possible....I'd really like to get around 160hp
full list of mods would be:
intake,
headers,
exhaust (no-cat...straight pipes?),
dx->EX head swap,
Crower Cam(not sure which one yet)
AEM cam-gear possibly,
and possibly crower valve train, pending on the cam i get.
Old Nov 23, 2006
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
like 157 or something... Just swap.
Old Nov 23, 2006
you mean K20swap? cant afford that ****
Old Nov 23, 2006
ex2k3's Avatar
diamonds she will pretty much have to
ex2k3 is a jewel in the roughex2k3 is a jewel in the roughex2k3 is a jewel in the rough
if you get everything available off the shelf for the d17 I would say 170bhp is the limit and that's being very generous. stg 3 cam, with aem ems, cai, straight pipes, high flow race header, d16 intake manifold, crower crank, lightweight flywheel, basically everything. It will cost a lot, in fact so much that a swap will look much better once you start pricing parts.
Old Nov 23, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
^agreed..
swap=more power for less money but more downtime
boost/swap>n/a build
Old Nov 23, 2006
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
Originally Posted by Sujak
k20a3 man, you can find a engine for like $1000 or less! and make 160whp+ i/h/e
What does that include though? just the block? or is that tranny, axles, wiring harness adn everything?
o and tuning, nice sig
Old Nov 23, 2006
kornsined's Avatar
Do it......I know i did! Look up xproductions DIY in the Forced Induction forum.
Old Nov 23, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
you have a auto civic. your starting at 90whp. good luck. youd have to be boosted to get those numbers and even then, your still looking at only 160whp at 5-6psi.
Old Nov 24, 2006
ex2k3's Avatar
oh **** he has an auto, nevermind your ****ed for power, turbo and n2o is the only way for an auto d17 and with that you'll have to be careful. lower my n/a numbers to like 130-135bhp. auto tranny ftmfl
Old Nov 24, 2006
RAZRBLD's Avatar
TEIN MAN
I used to have a Auto D17 I Swapped.
Old Nov 24, 2006
I think I'm doing pretty decent as-is right now.
Last time I went to the track (right after I put my headers on - but throwing a CEL for primary 02) I was running better times than an 04 base-automatic RSX (by about .5-1.5 seconds)
and now that I've got my 02 fixed again, I want to go back to the track when I have time, to see what I'm running now.
edit: the 17.7254 @ w/e was when I was stock. The time I was racing the RSX I was hitting high 16's
Edit#2: With the crower stage2 N/A cam, would that make the car idle pretty rough?
Old Nov 24, 2006
RAZRBLD's Avatar
TEIN MAN
I ran a 14.9 with a K20a3 swap i/e/h kpro my local track upkeep is shiat
Old Nov 24, 2006
s0ltker's Avatar
- hella tite y0 -
s0ltker is just really nices0ltker is just really nices0ltker is just really nices0ltker is just really nices0ltker is just really nice
gl with a NA d17.....do a swap if you can...
you can pick up a k20a3 or k24 for pretty cheap.
Old Nov 24, 2006
HondaLuver's Avatar
Its a celebration bitches!
not worth it on a auto d17. i had a auto before... they i turned to the dark side...
Old Nov 24, 2006
lumina5201's Avatar
lumina5201 is an unknown quantity at this point
haha, ill never go back to auto again
Old Nov 24, 2006
andyman97's Avatar
Turbo Guru
Yeah, that's a pretty accurate number. At 6 psi I made 195 whp stock d17a2. 02fpcivic made over 200whp at 5.5 psi. Few others have broken 200 whp on only 6 psi so yeah, you'll only get about 160 whp on 6 psi
Skunkone
Sep 24, 2015 04:38 PM
krazykoncepts
Sep 8, 2015 09:02 PM
KAMIKAZEEx
Aug 30, 2015 08:30 AM
carid
Aug 8, 2015 05:05 PM
