K24 Frank begins.
Re: K24 Frank begins.
can i take the k20a2 cams, vavles and the springs in put it on the k24a1 bare head and just use the cr-v harness meaing swapping the internals of the k20a2 and puting it in the k24a1, b.c i brought the k24a1 complete
TEIN MAN
damn this makes me want to swap my car lol i went to the junk yard but came up with nothing everything was stripped down to the frame itself but new shipment of wrecks coming in soon mnaybe week or 2
cant wait to see your finish product
Runumhard Or Go Home
Maybe a stupid question but is your motor in backwards?^^^. I know you know what you're doing so no pun intended i just noticed it and figured i would ask
you have to modify to the exhaust to match up to the downpipe.. k20 header and downpipe stop around where the shifter cables go into the car
I Hunt Goats, Rams, And Mustangs.
you bought those used huh? hope they dont bind on you like they are known for *well any k-swapped axle will do* thats what happened to mine i had to send um in for warranty repair.. now that they are outs, its about 50 bucks each time.
TEIN MAN
Well my build is going to be put on hold.. My grandpa passed away so im in Georgia taking care of things... Hopefully it will start up soon again.
Ok so does the K24 have even bigger hood clearance issues than the K20 or does the K24 mount kit address this and I thought that stock K20 headers mated straight up to an EM Civic exhaust? I'm piecing together my swap right now I have the option of K24 or K20 and I'm working out the details. Thanks guys, keep up the great work your success is keeping me motivated while I work on students wages to afford this stuff.
P.S.
What's the deal with the TSX tranny not fitting? You HAVE to use a K20 tranny?
P.S.
P.S.
P.S.
HOWEVER....
This is all assuming you will be using the type-s intake manifold. If you plan to use the rbc then there are more clearance issues to worry about
TEIN MAN
Well the OEM parts arrived today... RBC intake manifold, Lots of Bolts, Idler Pulley, Gaskets, hoses etc. Just awaiting the head. The Rockers are Sitting in DHL facility for 2 days now and no movement... Just called DHL and they are filing a complaint and it will be delivered Tomorrow before 12:00 they say.
