K24 Frank begins.
Old Jun 1, 2007
  #121
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Re: K24 Frank begins.
have fun with the rbc
Old Jun 1, 2007
  #122
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
pain in the *** to fit the RBC into our engine bay? Now DHL STIL didnt deliver the rocker assembly AGAIN! So I have to wait til Monday for delivery.
Old Jun 1, 2007
  #123
just remember.. a dremel or something similar will be your best friend
Old Jun 1, 2007
  #124
RAZRBLD's Avatar
TEIN MAN
Dremel away on the RAd Support so it fits? LOL This is going to be fun.
Old Jun 5, 2007
  #125
RAZRBLD's Avatar
TEIN MAN
If all goes well its goin in this weekend!!!!!!
Old Jun 12, 2007
  #126
RAZRBLD's Avatar
TEIN MAN
the head arrives Thursday.
Old Jul 17, 2007
  #127
RAZRBLD's Avatar
TEIN MAN
Hytech Header ordered for K24.
Old Jul 18, 2007
  #128
Kore's Avatar
Kore is an unknown quantity at this point
I have a question. My D17 just went out and was reading some threads and can't decide on NA or Turbo K. Anyways my question is, what is everyone doing for the bearings, is everyone i read about using stock OEM bearing or aftermarket ones, and if so which ones?
The reason i asked is that my D17 bearing where spun. A year ago my friends spun his bearing using nitrous on his Type S and ended up taking it in and getting the entire engine overhauled to take up to 1000 hp. they beefed the bottom end by putting in a B series custom crank since it's thicker than the type s. they also beefed up the bearings (thicker and stronger) and a whole bunch of other stuff sleeved and head work. I'm wondering if all these people that are doing the Franks and Turbos are going to have problems down the road with the bearings since it seems these engine's bearing were designed weak.
Old Jul 20, 2007
  #129
RAZRBLD's Avatar
TEIN MAN
please dont say your buddy has a b series crank in his k-series...LOL maybe he got a f22 crank with a modified snout.. but no way in hell does he have a B series crank in a K block. I went ahead and upped to ACL rod and Main Bearings along with Thrust washers... so hopefully i dont have the problem your friend does.
Old Jul 21, 2007
  #130
aznprid214's Avatar
aznprid214 has a spectacular aura aboutaznprid214 has a spectacular aura about
anyone have any idea what numbers this is going to yield? this seems to be more unique and possibly less money then just doin a k20swap. what do you guys think?
Old Jul 23, 2007
  #131
RAZRBLD's Avatar
TEIN MAN
all you need to buy is Mounts, Shifter Cables and Assembly... Then find a K24 accord complete for $850 then build it.
Old Jul 26, 2007
  #132
streetthrowback's Avatar
streetthrowback should not be trusted
i stared out with a complete k24a1 and a doing a head swap with a k20a2, what type of sensors would i have to change, will i be changing all the sensors on the head or is their some i can use??
Old Jul 27, 2007
  #133
RAZRBLD's Avatar
TEIN MAN
you need Crank Position Sensor (k20A2) Knock Sensor (k20a2) TDC Sensor (K20a2) Cam Sensor (k20a2) and you need a K20a2 engine wire harness.
here is a good sensor breakdown.
http://www.k20a.org/forum/showthread.php?t=21854
Old Jul 27, 2007
  #134
weird.. the only sensor i changed was the crank sensor... everything else i left the same
Old Jul 27, 2007
  #135
can i use a civic si harness?
Old Jul 27, 2007
  #136
where is the crank sensor located?
Old Jul 27, 2007
  #137
in http://www.k20a.org/forum/showthread.php?t=21854 the cr-v crank sensor is the same as the rsx-s
Old Aug 9, 2007
  #138
RAZRBLD's Avatar
TEIN MAN
I should have the beast on the road in 2-3 weeks!!
Old Aug 9, 2007
  #139
DsevenEm2's Avatar
This is Myspace
pics man...we wana see the progress not read it!! LOL good job by the way
u still sticking with the NA IS BEST! concept?
Old Aug 11, 2007
  #140
RAZRBLD's Avatar
TEIN MAN
you know it.... broke my digiAL camera... no good... but im trying to buy another camera. partyin in vegas right now...LOL
Old Aug 11, 2007
  #141
are you going to use the stock a/c compressor from the em2??
Old Aug 11, 2007
  #142
ac/ compressor or condensor?? cause u asked me condensor not the compressor
Old Aug 11, 2007
  #143
BigD001's Avatar
BigD001 can only hope to improve
I have a question when using a k20a3 or k20a2 tranny with a k24 motor do you have to have the gear ratio changed? cause I know that they have slightly deffrent specs.
Old Aug 11, 2007
  #144
sorry i meant a/c compresser
Old Aug 11, 2007
  #145
kpro has the option but you dont have to.. when kpro first came out it never had the option but now it does...
its more for kpro to help determine what gear you are in by using the math of speed vs rpm calculation... usually when using options in kpro that needs to determine what gear you are in... examples would be the boost by gear option
Old Aug 11, 2007
  #146
White0nGold's Avatar
White0nGold has a spectacular aura aboutWhite0nGold has a spectacular aura about
hey i just read the first page of this thread havnt gone through it all, but u said u got a k24a4 motor and ur gonna have valve clearence issues or so hondaluver said, isnt the k24a4 the element motor? not accord
Old Aug 12, 2007
  #147
BigD001's Avatar
Thanks xproductionz I didn't know the new version kpro did all that. I'm trying to learn evrythong before I buy my k24 in a couple of weeks
Old Aug 13, 2007
  #148
he is building the motor
Old Aug 13, 2007
  #149
RAZRBLD's Avatar
TEIN MAN
X2
I built the Motor using aftermarket pistons and connecting rods... So no valve to piston clearance issues.
Old Aug 13, 2007
  #150
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
alot of good information in this thread...
