Intercooler pipping size???
Old Oct 30, 2006
boostedEL's Avatar
boostedEL is an unknown quantity at this point
Last year i got the TSI kit and now i'm upgrading some stuff including my intercooler pipping. now with the kit, it comes with 2.25" pipes. now i'm wondering if i could go with 2.5" pipping without hurting power nor spooling?
Old Oct 30, 2006
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
i run 2.5 in my custom built kit without any spool issue
its approx the same size as your t/b
Old Oct 30, 2006
boostedEL's Avatar
But with a T25???
Old Oct 30, 2006
sorry my bad..i gapped that the tsi is a t25
2.25 will be fine, the upgrade at this point is not worth the money
Old Oct 30, 2006
boostedEL's Avatar
Money is not a problem and i'm doing it myself over the winter.... so lots of time... i just hope it wont rob power
Old Oct 30, 2006
im running a mid t3 and have not had any issue with spool or power loss...under full boost by 3200 rpm
but im not certain on a t25...what trim are those?
Old Oct 30, 2006
boostedEL's Avatar
i believe its .42... but not sure
Old Oct 30, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
upgrading to .5" bigger wont make a difference. stick with what you got, put your motivation to other parts of the system to make them better. don't fix it if it aint broke.
Old Oct 30, 2006
boostedEL's Avatar
well actualy i have a hole on the piece that leaves the turbo. i guess it kept hitting the motor mount.... your best bet is to fix that?
Old Oct 30, 2006
XSRCivic's Avatar
uh yeah fix that, get another one but then its kinda hard to mock that up without having it on the car.. goodluck
Old Oct 30, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Smaller pipes = faster spool
Bigger pipes will move more air, but with a smallish turbo, no need. I'm running 2" to the IC, then 2.25 out.
Old Oct 31, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
tsi kit comes with 2" pipes...sorry...and they are fine for the t25...why upgrade?
Old Oct 31, 2006
boostedEL's Avatar
so my best bet is to stay with what i have!
Old Oct 31, 2006
ronaldo9's Avatar
Why don't you just do what boilermaker did and have 2 inch piping to the IC and bigger piping after the intercooler. Perhaps you can even reroute your piping similar to dezods to enhance the flow. I know azchnchinksta (don't know if I spelled that right) rerouted his piping with his tsi kit. He's from Florida and he has a thread about it too. Just something to consider.
Old Oct 31, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
No need for you to upgrade piping or intercooler. It is a waste of resources. Piping and i-cooler big enough to handle way more power than stock d17 can handle. Just fix that little hole that you have.
Just concentrate your resources on bigger a turbo (t28 max), more advanced fuel system (AEM), clutch and .....more...
Have you thought of updraging to t28 turbo?
It should fit well with TSI mani and all piping, TSI desinged this kit to accomodate t25 or t28. You'll probably get extra 10-15% more power at the 7psi.
Old Oct 31, 2006
boostedEL's Avatar
Actually thats one of the thing i did consider but first i wanna go with biger injectors and better fuel management like e-manage or the PCS XFC. i wont investe in EMS cuz i'm not gonna do a reduilt.....well for now that is.....
Old Oct 31, 2006
You have TSI fuel system now? Stay with that. Emanage wont give you anymore power, but more headaches - thats for sure.
PCS is a good choice, but all in all its somewhere beetween TSI unit and emanage.
All these 3 fuel systems have their adavantages and disadvantages, but none of them I can say worth trading for another one. What they do and results you get is very similar, they are even in the same price brucket (PCS $500, emanage w/injectors & PnP harness ~$400, TSI box $400). Not worth trading one for another, unless you're bored.
Just what you have and to get AEM, will give you around 10-15% more power, if not more. Tuning abilities with AEM are unlimited so to speak.
Old Nov 1, 2006
boostedEL's Avatar
The reason i dont like the TSI injector controler is that u cant see your fuel maps. and the fact that you use 2 extra injectors. no performance shop in ottawa likes that set-up.
Old Nov 1, 2006
Why would you care if someone in Ottawa doesnt like your set up? Come to Toronto than, we like it here.
Why would you need to see fuel maps for?
As long as it runs nice for you, thats all that there is to that.
The choice is yours, of course.
Old Nov 1, 2006
boostedEL's Avatar
My best friend who owned this kit before i did went through 2 motors and it was installed by a shop so i'm a little worried about that. i dont feel like buying a new motor now.
Old Nov 1, 2006
ronaldo9's Avatar
I'm stating the obvious but it's all about tuning man. One guy can blow his headgasket on 5 pounds when Andyman for example has been boosted on a stock headgasket and he's pushing 10+ psi. 03-Acura-EL has been boosted for this long with almost no issues. Everyone's car is different so don't be concerned if ur friend blew up his car that you will. It will be a possibility but if you're tuned properly and the components are working like they're should you should have no issues.
Old Nov 2, 2006
burnhard88's Avatar
I Love Lamp
From: Ottawa, Ontario, Canada/ Richmond Hill, Ontario, Canada
burnhard88 is an unknown quantity at this point
hey man... would it be okay if i saw your setup in your ride sometime??? i'm in the ottawa area and i'm looking to get the tsi kit but with the t-28 ball bearing turbo instead of the t-25... would love to get a ride in that bad boy...
Old Nov 5, 2006
boostedEL's Avatar
hey i dont mind but my car in parked for the winter and its in pieces for some fixes but anytime when i put it back on the road. For sure we'll go out for a rip.
68camerors
Sep 24, 2015 06:18 PM
