ATTN: AEM EMS users, please read!
Old Sep 11, 2006
andyman97's Avatar
Turbo Guru
For those who know, I've been troubleshooting an issue with my car for the past year.
I think I've finally seen a little bit of light at the end of the tunnel. I've been getting timing errors counting up on my standalone which AEM told me was not normal and that either the cam or crank pickup was losing sync from the sensor somehow. So after tons of time, money and alot of work and sweat, I got in touch with a friend with a very similar setup as mine on the same standalone. Lo and behold, his car gets timing errors also. But his car runs perfectly fine with no problems.
So, I don't know. I have now sent my wideband controller in for repair, once I get it back in, I can hopefully pinpoint whether I actually have a problem or not. Time will tell.
I contacted AEM about it today and they said "they will look into it". I will keep this thread updated as it hasn't been determined whether this is actually normal or not....
Also, anyone running the aem on a k series, can you chec, your system and see if it continues counting timing errors as well? I'm wondering if its something with the d17 or the 1030/1070....
Old Sep 11, 2006
WilmncChris's Avatar
WilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of light
You are using the PLX M300 wideband. Ye mine is messing up. I just ordered a new sensor if it still does the same i am going to smash it with a hammer and post the vid on here.hahaha what did your wideband act like
Old Sep 11, 2006
andyman97's Avatar
Turbo Guru
It was stuck going from 14.6-14.8 and wouldn't go further up or down. Hopefully after they fix it, it'll fix whatever defect was there and last me....
Old Sep 11, 2006
GEEZZ looks like the PLX M300 is no good. Ye i might go with the NGK wideband
Old Sep 11, 2006
C2i0v0i1C's Avatar
SuperMODrizd
i have the innovate wideband
Old Sep 12, 2006
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
I am also using PLX M300 wideband. How can you tell if you have timing error?
My car seems run fine and wideband seems working fine as well.
Old Sep 12, 2006
andyman97's Avatar
Turbo Guru
Hook your laptop up to it and pull up the troubleshooting parameters. It will give a list with engine speed, engine load, o2 #1 voltage, stat sync, stat sync errors (which should go back and forth from 0-1), timing errors, cam-crank and cam syn on/off....
Your car probably is perfectly fine. According to AEM, this is "not normal." However, I'm not the only d17 experiencing this so it appears to me that although it may not be normal, it doesn't seem to affect performance. If you've had it for awhile and the car is fine, I wouldn't worry about it, I'm still waiting to hear back from AEM about it....
Old Sep 12, 2006
ex2k3's Avatar
diamonds she will pretty much have to
ex2k3 is a jewel in the roughex2k3 is a jewel in the roughex2k3 is a jewel in the rough
Subscribed. I'm interested in knowing more about this since I want to use the EMS with the setup I'm getting.
Old Sep 12, 2006
dezod's Avatar
7thgen Power Maker
Keep me posted Andy!
Old Sep 12, 2006
Michalo187's Avatar
Abortion Survivor
They better look into it....We spent 1500 for our units.
Old Sep 14, 2006
kezay's Avatar
kezay is an unknown quantity at this point
I also get timing errors going from 0-1-0-1-0-1 etc. The problem is that AEM says that this is normal. So I didn't pay much attention to it because my car works perfectly fine...
Old Sep 14, 2006
Well I hope that AEM finds a solution to this prob. As far as the PLX M300 prob goes i am trying a new sensor and see if that works. But ye Andy keep us up to date on this issue
Old Sep 14, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Well we dont know its even a problem. In ten minutes of engine run time I counted 6 errors at idle. My car has spent tons of time on the dyno and everything appears to be just fine.
Old Sep 14, 2006
andyman97's Avatar
Turbo Guru
Well, today I finally got my wideband back. I added fuel across the board on the #4 cylinder and that seemed to clean it up.....
Kezay, you're probably looking at sync errors going from 0-1-0-1. Your timing errors will give a minimum of one while cranking and continue counting up while you idle or drive around.
Supramk3
Jun 11, 2015 11:13 AM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
cukaracha
May 16, 2015 07:36 PM
vtechin
Dec 24, 2001 09:58 AM
Maximus
Nov 14, 2001 10:52 AM
