Help With Power On My Noz
yo i need help... i cant get the spray to work.. like everytime i run the wire to the daytime runnin lights or the acc radio the ignition coil fuse keep blowin under my hood. alos had a fire start a few times from skiny *** speaker wire.. it was a bad idea.. plz help thxx
well what we did wass..... we ran the wire from the solenoid to the ACC radio fuse under the dash, then we also ran the power from my botton to the fuse. and the ignation fuse still blew
i did that **** and it keep blowin my igniton fuse.. idk why! but i got it workin now.. the 38shot sucks! not a big diff. im sellin it and gettin the dezod V3 kit in like the next week or so.. turbo > spray
Lets give you some good advice: Get your money back.
A dry kit won't work as easy as you think with our cars. Second (and most important), you can't get it wired right anyway!
Just give up and buy a used wet kit from someone online.
new to wiring there man?? might want to check the amp draw on those solenoids. and also seriously rethink what critical engine electrical systems you might be screwing with to get you spray working....you might blow more than a fuse....
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
