Inlet filter for V3 kit solved
Old Sep 6, 2006
WilmncChris's Avatar
WilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of light
Ok guys me and paul but our heads together to solve the turbo inlet filter. I know he has gotten alot of emails asking about that so here you go.
http://img368.imageshack.us/img368/8...ture006tj5.jpg
http://img368.imageshack.us/img368/4...ture007mz5.jpg
http://img504.imageshack.us/img504/6...ture008pg1.jpg
http://img368.imageshack.us/img368/4...ture009fy9.jpg
Old Sep 6, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Sorry about the huge pic but,
Is that kinking that coolant line?
Old Sep 6, 2006
RHCP0801's Avatar
looks good
Old Sep 6, 2006
ajhdragon's Avatar
7thgens official a$$hole
holy big pictures batman
Old Sep 6, 2006
it hits the line just alittle. But it no where near kinking the line
Old Sep 7, 2006
Michalo187's Avatar
Abortion Survivor
how much does this fiter run
Old Sep 7, 2006
arpond 40 bucks. We were trying to go a cost effective way
Old Sep 7, 2006
Michalo187's Avatar
Abortion Survivor
I guess this ain't a bad way to go....It protects the turbo.
Old Sep 7, 2006
PiNoYxRaCeRxRH's Avatar
PiNoYxRaCeRxRH is an unknown quantity at this point
my cuzzo put like a screen mesh thingy on his turbo.
Old Sep 7, 2006
Well me and paul decided that we should use a k&n that would help more and easier for others who are looking for a turbo inlet filter
Old Sep 7, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
doesnt look for a very good solution. lol. that radiator hose is going to get really hot and do you want that hot air being sucked into the turbo?
Old Sep 7, 2006
skipbarber's Avatar
^what will it matter? filter or no filter, the turbo is sucking in air from the same place. besides, the top of the filter is plastic, it wont transfer nearly as much heat as say a steel pipe. my concern is that radiator hose having restricted flow..
Old Sep 7, 2006
Spoolin's Avatar
spoolin by you
just sayin it would be better off with a pipe routed elsewhere such as hear where the stock airbox resonator was located like the old SF kits used to do
Old Sep 7, 2006
Michalo187's Avatar
Abortion Survivor
^^^^ Either way i think the air it sucks in is gonna be hot. Where the sf was located it would still pick up a lot of heat. Yes this isn't the best solution in the world and it may kink the radiator hose a tiny bit but its still better than nothing....The radiator hose looks to be like it won't be affected
Old Sep 7, 2006
skipbarber's Avatar
couldnt you maybe get a longer radiator hose and bend it accordingly?
Old Sep 7, 2006
I mean i can make a pipe off of the turbo, but how cost effective would that be to the consumer. plus that is just another pipe that has to be polished like the charge pipes. I mean if the demand is there I will make one.
its not the hose that is the issue. The thermostat is actually the issue. It hits where the lower hose slips over the thermostat.
Last edited by WilmncChris; Sep 7, 2006 at 04:03 PM. Reason: Automerged Doublepost
Old Sep 7, 2006
speaking from a show car point of view, this would not be acceptable. the filter is smashed in there and even pushing the coolant line. now it might seem fine now, but over time youre gonna have a nice hole there with coolant everywhere from vibration. and dont say it wont happen. ive seen plastic make holes in metal from rubbing too much
Old Sep 7, 2006
RHCP0801's Avatar
there is gonna be an indent in that radiator hose basically forever now
Old Sep 7, 2006
well when I get time I will go about making a pipe for all of the show people. YOu would have to come off of the turbo with a short 45 or 90 degree. It just depends on where you want to route the piping and filter. But for now this is just fine for me. Stainless Steal pipe is not cheap unless you can get mass quanities
Old Sep 7, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Ive done a lot of things the cheap way but, i always ended up fixing it the rightway. Might be fine for now but months down the road id hate the see hot coolant spray right into the turbo.
Old Sep 7, 2006
not looking for the cheap way out. i am just trying new ideas a seeing now they fit. just give me time i have tons of pipe laying around just have to see if i have 3.5 inche pipe. its just a fix for now so that i do not damage the turbo.
Old Sep 7, 2006
ajhdragon's Avatar
my turbo was in about the same place i did a 3 inch 90 straight up coupled to a 3 1/2 inch 90 placeing my filter right on top the the tranny to clear the hose and thermostate. it was cheap, but worked i just used some old pipeing i had around from cold aitr intakes.
Old Sep 7, 2006
AJ, ye only prob is if it will fit with the factory fans. Looks like i will try to go up through the 2 hoses. i have a couple ideas. but ye you are right that way will work. I also want it to match the same as the charge pipe.
Old Sep 7, 2006
ajhdragon's Avatar
it shoudl fit wit hteh factory fans, my tubo basically sat on the fan houseing. just my intake pipe didn't match my charge pipeing which kind of sucked, but my turbo was more go than show and i did what worked, with what i had. Which is what I assume you did. I have a buddy with a turbo b18c1 and he is running the same kind of filter setup as you. All I can say is it works, so whats the problem.
Old Sep 7, 2006
well you know if i can make a nice inlet pipe for others then is fine and worth the time.
Old Sep 7, 2006
01turboed's Avatar
01turboed will become famous soon enough01turboed will become famous soon enough
ok this might sound like a dumb ? but you don't NEED a filter there right b.c. i don't have one .. its just there to stop dirt and things from getting in there right
Old Sep 7, 2006
yes you are correct.
Old Sep 7, 2006
01turboed's Avatar
so if i run a pipe to a differnt spot that would get coulder air would that create more turbo lag?
Old Sep 7, 2006
Randyh's Avatar
Randyh will become famous soon enoughRandyh will become famous soon enough
What turbo is that?
Later
Randy
Old Sep 7, 2006
Michalo187's Avatar
Abortion Survivor
Its dezods spec'd turbo from his v3 kit. I think for an individual its not a bad idea....but for a company like Dezod, if you try doing this its gonna take away some points from my book.....Its just not company material if you guys know what i mean
