low compression by adding head gasket...
Old Sep 1, 2006
asadrana83's Avatar
asadrana83 will become famous soon enoughasadrana83 will become famous soon enough
Hey...i am boosting D17 with stock internals...so i was wondering if i can add another headgasket to lower the engine compression as it will create more space between the head and the piston...infact another of my friend did the same on d16y8...he didnt get any problem with that...what do you think?? Will it add to the performance or rob it??
Old Sep 1, 2006
civic01vtec's Avatar
It's been known to be done and yes it will lower compression. I don't recommend it though. If you do do it, make sure to torque down the head a extra 5lbs.
Old Sep 1, 2006
dezod's Avatar
7thgen Power Maker
Don't skimp. True lowering of compression is done through pistons. They are only $549.00 for the set. You will have much more reliability and piece of mind knowing it's done right.
http://dezod.com/pd_dezod_motorsports_performance.cfm
Old Sep 1, 2006
asadrana83's Avatar
r these pistons forged or casT??
Old Sep 1, 2006
Michalo187's Avatar
Abortion Survivor
Hahahah yeah ONLY 549 i love how Paul says that....but he is right. I really don't think the head would seal properly if you do this...you could try it but if your serious about reliability and power just put in rods and pistons spend the extra 2 grand to be sure.
Old Sep 1, 2006
dezod's Avatar
7thgen Power Maker
Forged.
Old Sep 1, 2006
C2i0v0i1C's Avatar
SuperMODrizd
it will work for a short period of time. torque it once, and when it starts to seal up the head will be loose and ull have to retorque. the risk of blowing it greatly increases. and somewhere along the line i was told that doing that will also throw off the timing, ie increasing the distance the head sits on the block and using the same timing belt.
Old Sep 1, 2006
Michalo187's Avatar
Abortion Survivor
^^^ I doubt such a small increase in length could mess up the timing....but the point is i guess you shouldn't do this unless you have time to be messing around with your car.
Old Sep 2, 2006
andyman97's Avatar
Turbo Guru
That's why we have tensioners that allow adjustment of the tension on the belt.
Either way, its not going to last or seal properly....save yourself time and frustration.
159
Jul 5, 2015 09:54 PM
Jun 2, 2015 11:54 AM
zaboomafoozarg
May 30, 2015 09:21 AM
Supramk3
May 11, 2015 07:55 PM
GPMarzan
Jan 5, 2002 02:30 PM
