Rattling issues for k swapped civics
Old Aug 24, 2006
CdKoInU's Avatar
CdKoInU is an unknown quantity at this point
When you guys drive your cars, do you have major rattling issues? I just drove my swaped vic and i wanted to check with everyone if its a normal occurance with the swap. Thanks
Old Aug 24, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
how major is this rattling?
Old Aug 24, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
From what I have herd around its normal. I know everyone in my area with a B or H series swap there dash shakes and stuff does rattle. There was a post on here awhile ago about this. something to do with the motor mounts.
Old Aug 24, 2006
CdKoInU's Avatar
i dont know...i've been tring to figure out where it is coming from
BTW..the rattling only happens when I drive city street...once the car gets going on the freeway, it stops
Old Aug 24, 2006
PunkingCivic's Avatar
I need TP for my bunghole
do you have the street or race mounts?
If your the dude who got the type r from Eric in simi valley then you have the race mounts.
the poly mounts are stiffer and the idle was a tad high when it was in his car; causing it to vibrate loudly.
Old Aug 24, 2006
CdKoInU's Avatar
If your the dude who got the type r from simi valley then you have the race mounts.
ya...that me...hmmm..he never told me he got race mounts, but i never new it made that much of a difference
would that be it?
Old Aug 24, 2006
Jeff's Avatar
Jeff is an unknown quantity at this point
Even if you werre to just get the poly mounts for the d17a1 engine , the dash shakes like a mother. lol
Old Aug 24, 2006
would that be it?
Cool, Yeah it is way stiffer and vibrate alot more through the chassis. The most common and softest is the street, followed by the race for track cars, and extreme race.
Yeah you were getting all the info through your lady so you probibly didn't get that info.
Just get street mounts; hasport sells just the new poly inserts too, That way you just press the old one out and the new one in:
Yep here it is: http://hasport.com/catalog/product_i...6166a2a628d6fc
Update:
I spoke with ERIC and he said:
The front and rear mounts are ENJO: http://www.enjoracing.com
Call them about the inserts.
The side mounts are HAsport
Last edited by PunkingCivic; Aug 24, 2006 at 03:37 PM. Reason: Automerged Doublepost
Old Aug 24, 2006
yourinmyw0rld's Avatar
I drove Temo and ruben car and it doesn't shake
Old Aug 25, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
you will have rattles, I would check the hole in the underside of the hood if you still have PS. Slight rubbing in this area was my problem, once I cut it larger I was good to go.
Old Aug 25, 2006
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
Yea I was thinking the same with my civic. It rattles during idling and cruising the street.
Old Aug 25, 2006
kasimmmmm's Avatar
vibrates like a **** even with the softest mounts. and when the a/c is on... wow! thats why i avoid switching on my a/c, only use a/c when its REALLY hot and when I really need it!
Old Aug 27, 2006
CdKoInU's Avatar
i've been able to drive it around and i've noticed that it vibrates between 0-2k RPM... after that its fine..
however, I did notice that the car do shake a lot when on idle, plus the idle is pretty high and has a tendency to fluctuate on its own.
Old Aug 28, 2006
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
my buddy has a b18c in his hatch with race mounts and it rattles like a ho. I would say its those race mounts for sure. On the opposite I know a couple guys with K series swapped vics with the normal hasport mounts and the rattling is there but not as significant
Old Aug 28, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
rattling is normal.
Old Aug 28, 2006
ragingSPAM's Avatar
I just burnt my tongue
yup rattling is normal for engine swaps...especially with hasport or other aftermarket motor mounts...the bushings are thicker so it transfers all of the vibrations into the body of the car
Old Aug 29, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
mine doesn't rattle.
I am using the hasport mounts w/ street inserts.
Old Aug 30, 2006
HondaLuver's Avatar
Its a celebration bitches!
rattle rattle rattle... my k20a3 rattles at low rpms between 1-2k especially when i play with the clutch going up a hill...
**** when i had the k24 in. it felt like i had a big block v8 in that bitch... rattle was a understatement... it rummbled
Old Aug 31, 2006
CdKoInU's Avatar
thanks for all your help guys....it seems like my problem is a none issue and that helps clear my mind.
Another thing, how did you guy wire the hose for your PS? Mine seems to always have a kink and eventually overflows
Old Aug 31, 2006
adishman's Avatar
adishman should not be trustedadishman should not be trustedadishman should not be trusted
just vtec all the time and it will stop....j/k
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
15
Aug 19, 2015 03:12 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
McD
Apr 22, 2015 05:28 PM
