Tuning?
Old Aug 15, 2006
minorc's Avatar
minorc will become famous soon enough
Tuning?
I plan on putting a turbo in my LX and i'm pretty new to turboing, anyways.. from reading the turbo FAQ i can probably handle 6 psi of boost with stock internals. Where would i get my car tuned to run 6psi or any psi for that matter.. there aren't too many ppl that i know of in my city running turbo's and quite a few of the shops are pretty shady so where should i start looking for shops to tune my ride ? sorry if this is a ridiculous question and been posted a million times.
Old Aug 16, 2006
andyman97's Avatar
Turbo Guru
Check in the Canada forums....
Old Aug 16, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
get an EX head for vtec then turbo
Old Aug 16, 2006
dezod's Avatar
7thgen Power Maker
Well we can supply you with a kit, but tuning may pose a problem. Where exactly are you located in Ontario? GTA?
Old Aug 16, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
He is up North.
Minorc, speak to "Muscle Car" guys, they probably know a dynoshop near by.
Old Aug 16, 2006
C2i0v0i1C's Avatar
SuperMODrizd
WHAT?? where did that come from
Old Aug 16, 2006
minorc's Avatar
ex head? for turbo-ing... i know the vtec but is there another reason.. better compression? Anyways i would need a Dyno tune? I could probably go to Toronto and get it done, thats not a problem. Will it hurt to drive it un tuned?
Old Aug 16, 2006
ajhdragon's Avatar
7thgens official a$$hole
as long as the boost is turned all teh way down ,and your run on stock injectors yo ushould be fine until you get there. as long as its not to long.
Old Aug 16, 2006
dezod's Avatar
7thgen Power Maker
Honestly, stay LX. Lower stock compression can hold more pump gas. Not worth the return on an EX head.
You always need to dyno tune without a doubt and furthermore, T.O. has some excellent tuning shops.
Yes it can hurt you driving untuned. THAT can cause your motor to go bye bye. So becareful and stay out of boost if you decided to do so.
The person who said you can run stock injectors, is completely wrong. DO NOT DO THIS! ATLEAST run 310cc RSX injectors.
Lastly, we are the highest quality D17 turbo system manufacturer around. Email me for more details: paul@dezod.com
Old Aug 16, 2006
ajhdragon's Avatar
^^ with the boost completly turned down, why not run sock injectors UNTIL he goes to have it tunned then turn it up and add bigger injectors.
Old Aug 16, 2006
civic01vtec's Avatar
I've been running 8-9 psi daily for almost 3 years on stock injectors untuned and I have never had a problem yet. Still on the stock HG.
Old Aug 16, 2006
I run on stock injectos (TSI fuel system). The way tsi system works - if it doesnt see boost it is not adding extra fuel, I also have internal WG.
I just locked WG fully opened (disconected actuator and used wire to tie down WG arm in open position, 2 min of work) and was driving so for several days, untill I was done troubleshoting some minor issues.
Old Aug 16, 2006
minorc's Avatar
So i would have to install everything, turn the boost down manually right? and bring er to Toronto to get dyno tuned. Is a tune expensive? should i then follow up with a Safc and better injectors ?
does Dezod ship to Canada? I also looked at at turbo kit at procivic.com, The Turbo Specialties Extreme Turbo Kit for 2529.99, is the dezod kit a better kit?
does Dezod ship to Canada? I also looked at at turbo kit at procivic.com, The Turbo Specialties Extreme Turbo Kit for 2529.99, is the dezod kit a better kit? I just wanna make sure that im gonna get my complete $4-$5000 worth and have a kit that will last and not fry my motor. I'm a daily driver / night time idiot hahahaha i guess you can say that.
Old Aug 16, 2006
Well, you need some type of fuel/engine management system to tune with. Safc, e-manage or AEM ems. I have seen ppl run stock injectors with safc or type s injectors with safc. You are better off spending a few bucks more and going with the e-manage and type s injectors.
Old Aug 16, 2006
minorc's Avatar
Won't i need a laptop to run Emanage, and that i don't have.
Old Aug 16, 2006
dezod's Avatar
7thgen Power Maker
Sure we can ship to Canada. Not a problem. Our kit is all stainless steel charge pipes, stainless tig welded manifold, 2.5" stainless downpipe, tial 38mm wastegate, tial 50mm bov, T3/T4 turbocharger, stainless oil drain and feed lines, bar and plate front mount intercooler and iridium Ik22 spark plugs. Our kit is a far better value for performance. This system just made 171whp @ 5 PSI on an automatic tranny! That is unreal!
With respect to tuning, it's usually $75-150/hr. Spend the extra $$ and scoop some used RSX injectors of ebay or clubrsx.com. As far as engine management, I would go with the AEM EMS or the PCS XFC with Fuel Kit. Chris who dyno'd those numbers used the PCS XFC.
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
beanhead
Sep 24, 2015 12:04 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
