cel?
Old Jul 23, 2006
jacky599r's Avatar
jacky599r is an unknown quantity at this point
cel?
ive got a 0171code, it comes on once in a while and will go off by its own. a mech told me its either the pri 02 or sec 02. and yeah itsnormal thatit goes off automatically. ive no cat.and turbocharged. any1? cheers
Old Jul 23, 2006
andyman97's Avatar
Turbo Guru
Are you serious? You're wondering why you're throwing a cel with a turbo and no cat?
Look into o2 simulators, just do a search.
Old Jul 25, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
first off, po171 is a bank 1 system too lean code, not an o2 code. and if it goes off by itself then it isnt a serious problem, but you will still need a scanner to clear it although the idiot light isnt on.
Old Jul 25, 2006
Michalo187's Avatar
Abortion Survivor
without a cat you should always have the check engine light. If a light keeps going on and off and if its from running lean you better get that fixed or your gonna be introduced to headgasket work....thats not the thing you wanna do trust me
Old Jul 25, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
if u are getting any lean code. better get it retune or else...........
Old Jul 29, 2006
jacky599r's Avatar
ok.damn so its a too lean code and not a o2? ive check the plugs. it suggest the tune is gd...so still go for a retune? my AFR looks pretty fine.
Old Aug 2, 2006
it doesnt have to be running lean for too long to throw that code. so basicly your a/f can be nice but when your in decel or at whatever time its gonna read too lean for a second. its not a major code but id look into it...
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Luluharp
Sep 27, 2015 11:56 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
