Update on V3 kit install more pic update on full install! pg4
Old Jul 10, 2006
WilmncChris's Avatar
WilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of light
here are the final pics of the engine bay install. I got more pics coming later tonight or tomorrow.....
ID:	67382   Click image for larger version
ID:	67383   Click image for larger version
ID:	67384   Click image for larger version
ID:	67386   Click image for larger version
Old Jul 10, 2006
RHCP0801's Avatar
very nice man, get those pics up ASAP!!!
pics looks nice on the site
Old Jul 10, 2006
clrumivier4life's Avatar
clrumivier4life is an unknown quantity at this point
Awesome work. I'm so pumped to see it finished.
Old Jul 10, 2006
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
wow yea post pics when u can
as for the kit any welding NESSECARY??
can the oil tap be threaded instead of welded on?
i dont really like to weld as why
Old Jul 11, 2006
dezod's Avatar
7thgen Power Maker
No welding necessary at all. Not even the pan fitting.
Old Jul 11, 2006
dezod's Avatar
7thgen Power Maker
Originally Posted by WilmncChris
Hey guys, I have been working on the install of the V3 kit. So far the its been smooth sailing. No big Problems at all. I made life abit easier I removed the radiator so I am not jamming my hands all day long. As of this point I got the intercooler mounted and all piping is done. BOV and wastegate are on. I dropped the oil pan and will tap the pan tomorrow. I also have the RSX injectors in, but i will be machining some thread extenders so that the fuel rail can bolt down. Hops I did not miss anything kinda tired been a long two days. I will post some pics as soon as I get time. Paul at Dezod put some pics on thier site under 7thgen turbo kits. Hope you like.
Here are some of your pics.
ID:	67165   Click image for larger version
Old Jul 11, 2006
goodtimes's Avatar
is this kit going on a 5 speed or a auto?
Old Jul 11, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
more pics more pics!!!
Old Jul 11, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
definately more progress pics and of the end result!!!
Old Jul 11, 2006
dezod's Avatar
7thgen Power Maker
Our kit fits both, and Chris has an Auto.
Old Jul 11, 2006
RHCP0801's Avatar
what upgrades are you doing to your tranny?
Old Jul 11, 2006
AzNmiKex215's Avatar
2k1civic.com O. G.
sweet. My auto tranny should be fixed with TCI innards by the eng of august. However, i dunno if i should keep the car and turbo it or go with an RSX Type-S
Old Jul 11, 2006
Hey Guys, sorry for the lack of pics, I got so many I need to get all of them into photoshop. Well as of right now the only thing left is vacume lines, fuel system and the electronics.I installed two slim fans today along with the radiator. I will get my camera from the shop tomorrow and bring it home. I also made some female to male stud extenders for our problem we have for the fuel rail when we use the RSX injectors. I have to say DEZOD hit a homerun with this kit. It looks great and it has been really easy to install. If it was not so damn hot here in North Carolina we might be done. Just be patient pics are coming.
Old Jul 11, 2006
in the future you might want to do a diy on how to do the stud extenders for rsx injector use...ill be patient and wait for the pics
Old Jul 11, 2006
RHCP0801's Avatar
what have you done to the tranny? anything?
Old Jul 11, 2006
Boost Junkie, i machine them out of aluminum. I have a height adjustment issue to fix which is no biggie so when that is fixed i will be sending them to Paul at dezod so they can see what i created. But if anyone is really serious in boosting our civics pick up the phone and call Paul at dezod. This kit has been a breeze. As for my tranny i have a nice size tranny cooler that is mounted beside the front bumper. I relocated the horn for it to fit really well. It will be getting **** loads of air. I will be going the TCI direction in abit. But for now that is fine. I change my tranny fluid every 10,000 miles
Old Jul 11, 2006
dezod's Avatar
7thgen Power Maker
He has a stock tranny, and a tranny cooler.
Thanks for the kind words Chris.
Old Jul 11, 2006
here are some updated pics
here are a few extra pics hope you like.
http://img91.imageshack.us/img91/6870/p10001552zs.jpg
http://img114.imageshack.us/img114/5055/p10001581ke.jpg
Old Jul 11, 2006
dezod's Avatar
7thgen Power Maker
Lookin great Chris
Old Jul 11, 2006
holy huge pics batman...
if the extensions go well, you should have paul just make them and add them in with the rsx injectors for a little bit more money...
Old Jul 11, 2006
RHCP0801's Avatar
how long would that tranny cooler hold up for boost?
pictures arent that big
Old Jul 11, 2006
goodtimes's Avatar
and what kinda of #'s are you guys looking to get out of the motor b/c your v1 turbo kit put something like 150whp at 8psi, the v3 kit should put out more with the same psi level right?
Old Jul 11, 2006
tfnaaf's Avatar
BLDNPSI Mod
Just FYI to extend the fuel rail studs is much easier than your making it. Just double nut the exisiting studs and screw them out, then install longer studs and use a couple washers, and or make a spacer from some small tubing
Old Jul 12, 2006
then someone do a diy on it!!
Old Jul 12, 2006
HyaBoosta's Avatar
wow looks like a dam clean install. does the Turbo have a 90deg. welded on or are you using a 90deg. coupling?
Old Jul 12, 2006
Tfnaaf ye i know the usual drill but i wanted something alittle more clean looking and its takes 5 mins to make 2 of them.
Old Jul 12, 2006
sitinduk's Avatar
sitinduk is an unknown quantity at this point
The charge pipe has a 90deg. bend. Turbo outlet and coupler are straight. To get it to fit, u have to use a slimline fan.
Old Jul 12, 2006
You do not have to use a slim fan i just choose too. I am using 2 800CFM fans. On the stock fans you just have to cut out where the turbo and fan meet. But yes slim fans help out alot. I did not get much done today. I finished all the vacume lines, mounted the fuel booster, and started working on the XFC fuel system.
Old Jul 12, 2006
sitinduk's Avatar
You sure about that? I couldn't fit mine (charge pipe) between the front motor mount and the stock fan shroud even when I trimmed the shroud.
Old Jul 14, 2006
OK people its done!!!! Only thing that is holding me up is my PNP harness it came with female ends when it needed male ends on the plugs that came from PCS. No Big deal really could not get Dyno time til wednesday so i will have the adaptors by monday or tues. I will do some base tuning that day. I will take the final pics today. I wil be filling up the fluids, and rechecking everything....
