Advice for turbo guys here....
Old Jul 4, 2006
Hwoody77's Avatar
Hwoody77 can only hope to improve
If you haven't done a boost leak test, do it ASAP.
Total materials to actually build the tester will be under ten bucks, but it is WELL worth it.
My car was running fine beforehand, boosting fine, but just to make sure I did the test.
So I hook it up and I found a whole bunch of boost leaks.
I found one on my vacuum line that goes to my BOV, another on my third injector because of a faulty O-ring, another on my TB gasket and another on my intake manifold flange.
You will need a compressor though, or a hand pump (Although it'll take forever), you will also need a pressure gauge and/or a boost gauge.
But go out there and get it done, you'll be surprised at what you find!
Old Jul 4, 2006
soldierboi's Avatar
soldierboi will become famous soon enoughsoldierboi will become famous soon enough
ya thats a good idea...
hey im not boosted or anything but does the leak cause you to loose some hp? probly so huh?
Old Jul 4, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
how do you perform the test?
Old Jul 4, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
i think u just pump in a whole bunch of air into your engine and feel if any air comes out of anything. lol
Old Jul 4, 2006
Spoolin's Avatar
spoolin by you
so is this done similar to a leakdown test?
Old Jul 4, 2006
drunkenmagnum's Avatar
how do u find vacum leaks? i was told i might have one
Old Jul 4, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
how to build your own
http://www.vfaq.com/mods/ICtester.html
if you dont feel like building your own
http://machv.com/macvleaktes.html
Reginator
Jun 17, 2015 07:54 PM
Supramk3
Jun 11, 2015 11:13 AM
cukaracha
May 16, 2015 07:36 PM
wsking77
Aug 29, 2001 05:34 PM
