a question for the swap guys
Old Jun 11, 2006
djmota's Avatar
if you where able to take what you wanted from the rsx you where pulling the engine from what would you get? besides the obvious that is in the swap faq. will the rsx cruise controll work? also i am mounting the battery in the engine compartment. just made a deal for an k20a2 swap local.
Old Jun 11, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
you can use your own cruise control
wat would I get? I'd take everything. motors, harnesses, ecu, subframe, axles [sell them], brake booster, master cylinder, both o2 sensors [very expensive], front rsx motor mount.
a/c parts need to be from an ep3 though ... need d17 condensor, rsx compressor [should already have it w/ the motor]
about time oscar. ;P
Old Jun 11, 2006
kornsined's Avatar
what exactly is need from the a/c?
Old Jun 12, 2006
djmota's Avatar
ac lines from an ep3
should i get the fuel pump assembly? will it drop into an em2 tank?
Old Jun 12, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
you don't need the fuel pump
Old Jun 12, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
need d17 condensor [should already have it w/ the motor]
You can also use the type S condenser, either way you will have to make a custom line. My thought is to use the type S condenser and make a custom line from the D17 dryer to the condenser vs. making a line from the rsx compressor that goes all the way to the oposite side condenser. Also you can use the type S radiator. Some say that it fits right in, well this must be year specific (I am thinking it may have somthing to do with the change from 03 to 04) becuase on my 04 I did have to cut about 1/2" of a inside frame piece to get it to fit. It really was not that big of a deal, but even after it took some work to get into place.
Get the Power steering lines, atleast the one that bolts up to the compresor, becuase this fitting is different.
Old Jun 13, 2006
HondaLuver's Avatar
Its a celebration bitches!
after me beating him with all motor and he can't catch up to me with his nitrous... he knows he better come to the dark side... lol
Old Jun 13, 2006
djmota's Avatar
funny i remeber it the other way around. hell ya i'm done playing with the D now lets see what i can do with a real engine.
Old Jun 13, 2006
HondaLuver's Avatar
excelent, if you need any q's ask me...
Old Jun 13, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
come on over to the K side
thana
Jun 15, 2020 07:05 PM
SoyerOner
May 11, 2015 09:46 PM
zack22490
Apr 29, 2015 03:17 PM
redej2
Apr 29, 2015 01:47 PM
wsking77
Aug 29, 2001 05:34 PM
