Intake Air System Leak help
I'm wondering if anyone else is having this problem..im throwing tha code P2279 .. which is Intake Air System Leak.. but all my pipes are securely fastened.. i've taken them out and put them bacc in a few times alredy but im still throwing tha code..i've also check bov/sensors/lines etc.. anyone have any suggestions?.. thx
that sounds like a MAP sensor or throttle control code. There's no way its picking up an loose clamp, I agree, its picking up an internal leak to the TB or the IM and is either throwing the MAP off, or something like the idle control valve doesn't like what it sees.
OR
You have nothing in place to hide boost from the map sensor, and its reading positive pressure.
OR
hmm i'll check that out ..yeah b4 my car was idling all crazy .. like to 3k wen im in neutral .. but after taking all my piping off and puttin it bacc in.. tha code went away but i still got that leak.. thx for tha input guys
mievil
Apr 28, 2015 11:02 PM
cloudguy
Apr 28, 2015 05:02 AM
